Home > My Defender > My defender |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
Looks really good that does not over the top on the cosmetic bling. Dark green as well. Same as me, the only colour IMHO for a Land Rover. Had Discovery 2,3,4s in grey and black. But, this is the the colour to have. When the next gen defender comes out I'll get a dark green one of those to go alongside my old Td5! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
9th Dec 2014 10:38pm |
degsey Member Since: 27 Nov 2014 Location: Mann Island Posts: 13 |
thanks I just need to short the suspension out to give me a better ride, my kidneys are battered with it
9th Dec 2014 10:53pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
If you find a solution let me know i was going to try these:
http://www.alivetuning.com/alive-boutique/...duct_id=84 but im not sure whether there will be any significant difference in ride for the £400 notes required. |
9th Dec 2014 11:53pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
Nice looking truck
I have those shocks and a set of alive springs on my 110 .. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
10th Dec 2014 12:15am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2638 |
There is, for cornering and performance wise there excellent. |
10th Dec 2014 12:36am |
Do you notice a significant difference carrot? |
10th Dec 2014 1:03am |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
Here's my 90 fitted with -2" springs from Extreme 4x4 highly recommended
http://www.defender2.net/forum/topic31901-15.html more comfortable than standard and being progressive rate reduced body roll as well the standard rate Puma springs are too hard unless you have some load in your truck changing the shock won't help the bouncing and harshness you have now also Paddocks are cheaper http://www.paddockspares.com/brands/bilste...7-td5.html |
10th Dec 2014 1:36pm |
I do like the lower look but its killing my back such a hard ride
10th Dec 2014 8:05pm |
change the springs thats what gives you a harsh ride even worse in a Puma as the springs rates are higher than a TD5
i tried both Alive & IRB ringing and emailing both got a txt off 1 of them saying couldn't take my call and other never answered my emails or phone calls!!!! so rang Extreme 4x4 spoke to Digby he gave me great advice and matched the springs to what i use the car for so progressive rate springs so its nice and soft when just driving along but if i load it up or start cornering hard the spring rate is stiffer giving less body roll and the ride height won't drop when loaded. so even though its lowered it rides and rives better and is more comfortable, also it doesn't sit arse down anymore its all level now even the wife has just been out in and says she can't believe how much better it is than before it drives so much better you can even leave the standard shocks fitted if there aren't tired or worn out, do you have Anti-roll bars fitted? |
10th Dec 2014 8:49pm |
Ive got the standard shocks fitted, I got the springs from extreme 4x4
10th Dec 2014 8:52pm |
weird you have such a harsh ride then if you have springs fitted already, but it does depends on what spring rates you went for
10th Dec 2014 9:40pm |
I will call them in the morning
10th Dec 2014 9:42pm |
any news on what you have fitted?
11th Dec 2014 1:19pm |
I never got chance to call them today
11th Dec 2014 9:31pm |
