Home > In Car Electronics > wiring fault
Andyred90
wiring fault
quick question,
No reverse light and brake lights not working.
Where should I be looking??
Andy
Post #377033 7th Dec 2014 2:20pm
gilarion
Which Model?
I would first start with the fuses then a multimeter to check live at the conectors if you have live then check earth. nine times out of ten it will be an earth problem.
Post #377039 7th Dec 2014 2:44pm
Yeah, as above I'd say earthing especially seeing as it is two different lighting circuits.
I'd try adding a temp earth and see if that solves your issues, also check or unplug your trailer socket if you have one.
Post #377042 7th Dec 2014 2:53pm
munch90
the earth for rear lights is on the drivers side (rhd) of the transfer box beside the seat box
Post #377048 7th Dec 2014 3:14pm
Andyred90
Hi ,
Its a TD5 and there is a wire taken from the Negative terminal of the battery into the box under the drivers seat but its a bodge and the wire has chaffed where it comes out of the passenger side into the other side so I will replace this before doing anything else.
Andy
Post #377049 7th Dec 2014 3:23pm
gilarion
That's your problem that's the earth for the reversing and brake lights I would say..
Post #377067 7th Dec 2014 5:09pm
dorsetsmith
same problem 2003 TD5 90 HT earth retune missing across rear beam from driver side
earth header is behind radio. I jond new wire in loom at towing socket driver side rear, used small split conduit to run the cable from one side to the other in side the rear beam
heat shrink connectors are good for job Thumbs Up
Post #377073 7th Dec 2014 5:39pm
Caterham
having just read this I'm really hopeful it's solved my long standing 'problem'......
I've been 'playing' with the transfer box recently (like 2 days ago.....wiggling it to check on rubber mounts, lubricating the linkage etc and it seemed to fix my 'problem' (rattling like injector knock, poor gear change etc) until this moring - no brake lights.
having read above and the mention of earth for brakes next to transferbox Idea
I wonder whether this will be the answer to all my LR woes ?
it would possibly tie in with the intermittent circuit fault once spotted on the clutch switch (I presume it uses the same fuse?).
If only I could find the chance to crawl underneath today - but can't. that said is it possible from below or will it have to be from above?
many thanks.
Post #379589 17th Dec 2014 7:41am
munch90
the earth is on the side of the transfer box drivers side , quite easy to get to from underneath
Post #379720 17th Dec 2014 7:19pm
