Home > Td5 > Heat gauge reacting to throttle response.
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Hello all, this morning on my way to work I noticed my temp gauge was moving to the input of the accelerator, if i revved her the needle moves instantly down to the cold end and as the Rev stabilises ( to idle ) the needle returns to proper operation position. I will be posting a video, can anyone shed some light please.
Post #376379 4th Dec 2014 5:22pm
ttuck3r
Here is the video of what happens.
Post #376386 4th Dec 2014 5:38pm
ickle
Bad earth??? Block to chassis / body
Post #376413 4th Dec 2014 6:48pm
munch90
I would go with bad earth , or there used to be voltage stabiliser on the back of the gauge cluster that could effect the needles but normally would effect fuel gauge as well but also now days alternators are a bit smoother output then years ago , so I would start with earths checking
also might be worth checking alternator voltage, just in case
Post #376416 4th Dec 2014 6:55pm
ttuck3r
Well I got to the bottom of my fault that was causing my temp gauge to fluctuate with input from the accelerator, it only took a month and a half.
Post #390061 18th Jan 2015 11:35pm
mk1collector
And it was?
Post #390062 18th Jan 2015 11:39pm
leeds
Come on spill the beans!
Brendan
Post #390063 18th Jan 2015 11:40pm
ttuck3r
Haha, so I was installing a new LED light bar and red bison boomslang headlight loom, when running wiring through the bulkhead just behind the dash through an existing grommet and that's when I noticed two wires just behind the brake booster on spade connectors were apart which I connected up and forgot about it, I didn't think anything of it but when I went to test the light on a wee drive, low and behold no more fuel gauge rev counter 👍
Post #390092 19th Jan 2015 7:55am
ickle
So the earth terminal on the bulkhead was off?
Post #390282 19th Jan 2015 6:26pm
ttuck3r
well according to the workshop manual this isn't a recorded earthing point, the earthing point is on a ring crimp bolted to the firewall, so I have no idea what this is for!
Post #390371 19th Jan 2015 8:51pm
