Home > Puma (Tdci) > Rear diff leaking |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 135 |
Jonno
Just had exactly the same just 4 years old, 16000 miles and seal has started leaking. Luckily, has extended warranty and has been replaced under warranty. Tony |
31st Oct 2014 10:16pm |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 |
Lol I hope that doesn't mean the design life is under 20k miles!
Mines not under warranty, so hoping it will be quite cheap to fix although I dare say a total pain to do. Jonno |
31st Oct 2014 10:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
Check the breather isn't blocked, cheapest option number 1.
Replace the diff oil seal option number 2. If the above still fail a new flange and diff seal. On mine until recently the breather never was blocked but leaked, so the seal was changed. It then still leaked....... I then had the seal AND flange replaced as per dealer recommendation and the leak is completely cured. I'm guessing the flange was worn so even with a new seal its still leak. |
31st Oct 2014 11:47pm |
Good advice there. I hope the flange isn't worn.....#iss poor if it is at 18 k but wouldn't surprise me !
31st Oct 2014 11:56pm |
Mine started about 28k I think, after I did a heavy ish recovery.
Have you just been using it normally? If you have might be worth mentioning to LR the exceptionally low mileage for an issue to arise. |
1st Nov 2014 12:30am |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
Done around 450 miles in 2 days in my 51' Td5 county on the way back from a camping holiday .... The leaks appear to have worsened.... Gonna park up all use the Mercedes all next week and see if they slow down. I wish it was only my rear diff that leaked abit! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
1st Nov 2014 12:37am |
Not had time to look into this but apart from the leak that's started around the input shaft it also seems to have started leaking around one of the bolts holding it together... This is making me think it's more likely to be the breather problem as mentioned before on this thread. I presume the back diff is vented to one of the collection of breather pipes under the bonnet?
If so the bonnet end openings are clear, not sure if they block where they go into the diff. Will have to investigate further. Jonno |
14th Nov 2014 6:14pm |
Photo would be good if possible.
14th Nov 2014 6:30pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
My rear diff seal went at about 8K due to blocked breather.
Rear breathers normally vent at the back somewhere not under the bonnet unless extended. Very easy to find the vent position, follow the pipe from the top of the axle, normally about centre on one side, and you will find the end position. Then remove the pipe and check for a blockage somewhere along it's length. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
14th Nov 2014 6:41pm |
Will try and stick a pic up in the next day or so, if it stops raining. Just hoping unblocking the breather stops the leak and it was just excess pressure forcing the oil through.
Jonno |
15th Nov 2014 6:52pm |
Well
Less than 400 miles since it was replaced and it is worse than before, dripping oil on the drive! Click image to enlarge Click image to enlarge Click image to enlarge |
1st Dec 2014 8:54pm |
That is a bad one, much worse than what I had.
If it was done at main dealer I expect you'll be heading back. |
1st Dec 2014 9:53pm |
Yep, main dealer. I have emailed them.
I have already had issues with the dealer and I am far from impressed. |
1st Dec 2014 10:06pm |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1621 |
Hi glad to see there quality has improved since we had our rear diff oil seal fail on our 2010 puma at about 6 weeks old less than 1 k miles,never towed anything never offroaded either Cheers Paul tash n barney
2nd Dec 2014 6:52am |
