Home > Technical > Noisy Puma
Smudger
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Noisy Puma
So I took the Puma out for a drive today and after a couple of miles I got on to the motorway and was aware of a real din coming I think from the transmission. I say this because it's not engine Rev dependent or changes if you coast.
Steering, gear changes all seem normal, the vehicle is handling and feels as it should. any ideas, where should I start? It's a 57 plate Station Wagon with 75k on the clock.
Ideas and thoughts appreciated.
Smudger 08 110 Puma Station Wagon
65 Jaguar XF Sportbrake S
99 Elise 111S
Honda XR250
42 Royal Enfield Flying Flea
43 Matchless G3L
Post #375369 30th Nov 2014 9:10pm
ickle
Prop shaft joints? Early ones had no grease points IIRC.
Keith
Post #375372 30th Nov 2014 9:14pm
Smudger
I changed the front for a Bailey Morris extreme a couple years as the original was proper trashed. That was only noisy under load but I'll check them both.
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #375375 30th Nov 2014 9:19pm
Smudger
Noisy Puma
I've now checked the props, wheel bearings and had the wheels rebalanced. I'm wondering if the hand brake is playing up, possibly stuck on, anyone care to comment?
S 08 110 Puma Station Wagon
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #376165 3rd Dec 2014 7:42pm
landy andy
Is common for the handbrake to be poorly adjusted, which then causes noise especially once warm. Take for a drive then feel temp of brake drum.
Andy
Post #376205 3rd Dec 2014 9:30pm
Smudger
hmm, a quick test drive, noise present but cold brake drum. this is annoying now.
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #376231 3rd Dec 2014 10:11pm
Smudger
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #376234 3rd Dec 2014 10:16pm
