Home > Wheels & Tyres > 235/85/16 vs 235/70/16 BFG AT KO's thoughts please?
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
currently have Original boost alloys fitted 235/85/16 BFG AT's fitted
but looking to buy some sawtooth alloys and wondering about fitting 235/70/16 tyres instead
any pro & cons for this?
TD5 90 and is mainly used on-road with a little off-road but nothing serious
Post #374617 27th Nov 2014 4:26pm
JAY BOY
Wales
Hi
The rolling ratio would be out by nearly 9 percent.
Your speedo will be out.
Overall diameter: 806mm 235.85.16
Overall diameter: 735mm 235.70.16
Difference in diameter: -8.81%Actual diameter change: -71mm We recommend a MAXIMUM of +/- 2.5% difference
Hope this help Thumbs Up
Post #374621 27th Nov 2014 4:50pm
Cupboard
Lower profile so will be marginally less vague round corners but have a harsher ride. Whether you'd notice or not I have no idea.
235/85=31.7" diameter and 100" circumference
235/70=29.0" diameter and 91" circumference
Back of the envelope, doesn't take in to account the real world etc etc but that's a noticeable drop in diameter. You go 10% further on the 85s than you do on the 70s per revolution. That's a fair change to the gear ratio.
You're also going to reduce ground clearance by over an inch and reduce your traction, but you say that probably won't matter. The other thing is a reduction in unsprung mass which is a good thing, again I have no idea if you'd notice.
Post #374623 27th Nov 2014 4:55pm
Personally I think that 235/70R16 tyres would look absurdly small on a Defender.
235/70 is only marginally taller (1") than the old 600x16 tyres fitted to Series SWBs and early 90s, albeit half as wide again as a 6.00 (at 9.25").
I am not sure what benefit you expect, or are looking for, but a 235/85 would in my opinion look and perform better all round.
Post #374630 27th Nov 2014 5:34pm
Last sentence above is my view also, I think you'll find it'll not look right at all.
Post #374633 27th Nov 2014 5:44pm
Cupboard
A friend has 245/70s or 245/75s on his and they do look a bit odd and they're bigger.
Post #374740 27th Nov 2014 11:36pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Fitting 235/70/16s to your Td5 will reduce the already low gearing even further by about 10 per cent, not something I would choose to do ! 2005 Td5 90 XS
Steve
Post #374745 27th Nov 2014 11:48pm
Hufflepuff
If you are thinking of getting new BG Goodrich KOs, then in case you haven't noticed they have just released an updated version, the KO2. It was out in America at the beginning of the month but I've yet to find a local supplier to the UK. I'm first in the queue though!
Post #374748 28th Nov 2014 12:22am
silky16v
superb thanks to all i'll just stick with the 235/85/16 profile then and use the tyres i have fitted already on the new alloys
Post #374791 28th Nov 2014 11:01am
