Home > My Defender > Fitting Lazer RS4 Lights
Gingerdigit
England 2013 Defender 110 Puma 2.2 XS DCPU Corris Grey
I am fitting a pair or Lazer RS4 light to my 1 year old Puma Defender.
Is there an ignition feed easily assessable in the engine bay that I can get a signal wire to the relay to operate the spotlight side of the lights to save me getting a cable in to the dashboard area?
Regards,
Rob
Post #373471 22nd Nov 2014 2:08pm
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
I've fitted Lazer RS and ST lights to my Puma, but I'm having a little difficulty understanding your question Whistle
Are you after a full beam trigger for the lights or an ignition-switched feed for the drl portion of the lamps?
I used a dashboard switch for the drl portion and spliced into the full-beam trigger wire in the harness at the rear of the nearside of the engine bay for the full-beam triggering. If memory serves (and I've done this to both MY11 and MY13 Defenders), you need to splice into the blue wire with a grey trace at the harness at the rear of the nearside of the engine bay.
I'm not sure if this is helpful, but I'm trying!
Cheers,
Joel
Post #373831 23rd Nov 2014 10:41pm
