Home > Td5 > Clutch slipping under power
Page 2 of 2 <12
bell-auto-services
Apart from the very good omments above. If the thrust washers on the crank are warn, under load the crank moves slightly and can cause clutch slip even on low milage cars.
A quick fix/test without measuring crank end float is to put a 2-3mm spacer between the slave cylinder and bell housing spacing it away which gives the clutch fork rod a little more room to move.
Pete
Post #370906 10th Nov 2014 9:44pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Thanks for the reply Pete - I guess I'd have to make a spacer in order for the slave cylinder to seal properly to the housing?
Post #370931 10th Nov 2014 10:49pm
bell-auto-services
Yes you could make one or get a spacer from landrover FRC2402 for a V8 or 300TDI
Post #370934 10th Nov 2014 10:55pm
landy andy
I just used aerosol brake cleaner with hose on from crank sensor and bell housing drain. Have you checked bell housing drain? When you do/did makes sure hole is clear as it can get sealed/blocked from inside.
Andy
Post #370935 10th Nov 2014 10:58pm
Lambley
Brill, I'll do the seals on the FPR anyway, clean with brake cleaner and see what happens, then try the spacer.
Thanks very much for your inputs, It's much appreciated.
Post #370936 10th Nov 2014 10:58pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
just another note i tried the seals first on my FPR and it didn't fix the issue i had to buy a new FPR of the same guy
got to be a dab hand at removing and refitting the FPR could do it all in under 5 mins
i then attached a 30cm long piece of clear pipe to the FPR vacuum connection and tucked it behind the starter motor, so i can see if it ever starts to leak again and if is does it won't go all over the bell housing
heres the FPR i used http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...27c85ee4e0
Post #371004 11th Nov 2014 11:19am
silky16v
Pete
are the thrust washers easily replaceable when the sump is removed?
would you advise changing them even if there is no little or no play?
as i'm removing mine to check the oil pump bolt while the engine is out, and replacing bolt with new LR part
Post #371007 11th Nov 2014 11:28am
bell-auto-services
Yes easy to fit with the sumo off. Worth doing as prevention if you have the engine out for sure.
Pete.
Post #371690 14th Nov 2014 9:38pm
Lambley
Still not done mine yet, been moving house today. !!
Post #371692 14th Nov 2014 9:50pm
Lambley
Well, after changing the seals on the fpr and flushing brake cleaner through the crank sensor hole it was still slipping, so I flushed water through the crank sensor hole a few times and it now appears to be sorted, the clutch plates must have had diesel on them.
Thanks for all the advice, now seems back to normal. Cheers
Post #372766 19th Nov 2014 4:30pm
dorsetsmith
mine did same thing till I replaced the FPR Thumbs Up
Post #372813 19th Nov 2014 7:02pm
Page 2 of 2 <12
