Home > Td5 > Anti roll bar clarification
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Hi im needing new anti roll bar bushes, so ive decided to go for a new kit with poly bushes, but while i was searching on here for info did i read that some early TD5 90s will require other bits, can anyone verify this kit will fit a 1999 TD5 90.
Thanks
this is the kit i was looking at: http://www.paddockspares.com/stc8156aapy-a...ushes.html
Post #371546 14th Nov 2014 12:10am
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Hi
The kit you have chosen should be fine. I bought something similar a while ago to fit to an early Td5 90 that had no anti roll bars and it worked ok. Sometimes you see the knuckles hanging down below the axle , people fit them the wrong way up because its easier than fiddling with the bolts to make them miss the radius arm bolts......bodge Rolling Eyes
Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #371552 14th Nov 2014 12:26am
ttuck3r
Thank you, I will be ordering that up.
Post #371574 14th Nov 2014 9:11am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You may need different rear anti roll bar bushes and clamps as they are smaller on td5's , well they are on my 03 and 05 90
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #371616 14th Nov 2014 1:44pm
ttuck3r
Would you know what part numbers they are.
Post #371702 14th Nov 2014 10:58pm
derbywill
Yes you need 2 of EGP1661L and 2 x EGP1889
Regards
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #371856 15th Nov 2014 8:53pm
ttuck3r
Thank you.
Post #371857 15th Nov 2014 9:29pm
