Home > Puma (Tdci) > Hi/Low gear selector |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 |
Okay, what's the best way to mangle this control on a new stiff Defender. It's on High and I can't get it into neutral or low. I've tried the two methods in the handbook. It's only three days old and I need to show the beast who's the boss. Maybe I need a trainer?
27th Jul 2010 10:37am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
I wont disagree - but they dont actually fill the cars. They stick a load of pipes onthe parts and scan the barcode and hit fill - the computers do the rest quite impressive to see - especially the range rovers with the standard rig Mike |
27th Jul 2010 4:34pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
Sure those computers get corrupted by viruses as my gearbox had an excess of 2 liters Puma 110" SW
27th Jul 2010 4:45pm |
Probably pressed fill twice, and the rest overflowed. You want to see the number of batteries left connected from Friday to monday that are thrown! Mike |
27th Jul 2010 4:47pm |
Thanks harveyg77, I'll try that now. Maybe off to dealers as I have some other issues now... |
28th Jul 2010 8:22am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
Personally I found the high/low change and diff. lock levers easier to use on our current Puma than on any other Land Rover I have driven. 1982 88" 2.25 diesel
28th Jul 2010 8:28pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8123 |
the trick is to always have the main gearbox in a gear when you do it. The clutch can then be used to aid main gearbox alignment.
Low - High can be done on the move once the knack has been found, but as with High to low i would come to stop first until it has been perfected! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 29th Jul 2010 6:45pm. Edited 1 time in total |
29th Jul 2010 11:12am |
Joe90 Member Since: 21 Jan 2010 Location: UK Posts: 95 |
Usually what I do is put my landy in neutral on a slight slope of some sort and depress the clutch, then I give the transfer box a good push from high range to low range and let the vehicle just roll back a little and it seems to slip in nicely. Not sure if the way i do it is recommend, but it works.
Best of luck. |
29th Jul 2010 4:15pm |
no offence mean't, but no its not recommended, certainly not by LR anyway. if your in neutral there is no way of aligning the main gearbox if its out a bit either. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Jul 2010 6:45pm |
