Home > Technical > Battery
mse
Battery
Im looking for a battery that could fit either alongside or in a T shape with the standard main battery.
Any ideas?
The winch and car will run off the main, this one will be a deep discharge leisure type to run probably camping stuff and possibly some lights, maybe an inverter.
Forget the split charge element at the minute as im still split between 3 options. Full management, intelligent or simple relay - so leave me to ponder! Mike
Post #37095 26th Jul 2010 9:15pm
discocuzzy
Whistle Whistle
There aint much room in there Mike, i dont know if changing the layout will give you anywhere near the capacity you need. You cannot teach stupid people to do clever things
Post #37100 26th Jul 2010 10:04pm
mse
thanks...but will the odesy (looks like 1500 in the pic) fit with the standard battery - i didnt think it did??
I dont want 2
What about (pains) optima yellow top
As i get normal batters (new) for about £10-£20 any other size ideas? Mike
Post #37101 26th Jul 2010 10:08pm
discocuzzy
I had 2 optimas but they didnt fit unless i changed all the battery lengths when i changed the orientation with the D44 base.
I think you will really struggle to get anything other than a small 12v motorcycle battery in there in the standard configuration and im not sure you would get the longevity you would need without a split charge etc You cannot teach stupid people to do clever things
Post #37102 26th Jul 2010 10:13pm
landy andy
You can fit a standard battery and an oddesy in at the same time, but it is tight. They are great batteries.
Will see if i can find the photo.
Andy
Post #37116 27th Jul 2010 7:22am
landy andy
Does this work????????????????
Andy
Post #37117 27th Jul 2010 7:34am
TACK
Thumbs Up thanks andy. have you fitted a winch isolator in there as well? my isolator is located behind the standard battery in your picture, i.e at the front of the passenger seat. was wondering if you combo would allow my isolator to remain where it is. Question
If it can be done then, I think I will do the same as you before my next trip Thumbs Up
Post #37139 27th Jul 2010 12:08pm
mse
Thats along the lines of what im thinking!
I know you can fit the standard battery in 3 orientations so far (as shown in that picture, the reverse and the standard position)
Fitting the standard battery as shown from my calculations leaves a reasonable amount of forward "room"
Im sure ive seen a battery (normal type), slotted next to the standard where the depression goes. Mike
Post #37150 27th Jul 2010 4:28pm
discocuzzy
The main thing to make sure is that the install is totally secured, i see Landy man has used some additional support braces to make sure nothing moves around negating the possibility of battery shorting.
Good use of space there as it is Effing tight! Thumbs Up
Landy Andy is that a Puma battery box or an earlier defender?, im sure my TD5 had a lot more room than the current puma i have? You cannot teach stupid people to do clever things
Post #37154 27th Jul 2010 4:37pm
mse
Found it! this is the "bad boy"
http://povman.gallery.netspace.net.au/album02/16072010_012
2 55a/h optimas
Thanks povman Mike
Post #37156 27th Jul 2010 4:44pm
landy andy
The set up that is in that photo is an early photo of my 04 reg Td5 battery box, before fitting second Odessey. The original battery needed to be at the front of the compartment as is too tall for the bat box when on the twin mounting plate.
Andy
Post #37165 27th Jul 2010 8:59pm
discocuzzy
Cool Andy...what i thought though TD5 battery box is bigger than the puma..MSE check Povmans..im sure you cant mount the batteries that way without changing the length of the cabling at least You cannot teach stupid people to do clever things
Post #37166 27th Jul 2010 9:38pm
mse
Cable is a piece of cake the + reaches - as you can see.
The negative wont reach directly, but that isnt a problem as it only goes to 2 places under the car so an easy one to extend in a variety of ways
Other than that (and leveling the box floor) i cant see any other issue?? - i know where all the links etc are going plenty of space for them (my secret for now Whistle Thumbs Up ) and the there looks to be enough space for the + fused link and measuring the battery box it is more than wide enough (the slope allows extra space at the sides the battery wouldnt be able to use. Mike
Post #37174 27th Jul 2010 10:00pm
discocuzzy
Sounds like you have it sussed,Best stop natterin and crack on then nipper Thumbs Up You cannot teach stupid people to do clever things
Post #37196 27th Jul 2010 11:30pm
mse
Crossing t dotting i's is what im doing - had to find the battery size of those that fit to work out the size needed and which one/how much.
Thanks Mike
Post #37224 28th Jul 2010 3:10pm
