Home > Maintenance & Modifications > Rear window break light problems
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I have had an issue with my rear window break light
the metal strip fitted in the window that feeds the power to the light has broken at the terminal to the light fitting.
I have fitted a temporary cable from the door inlet feed in to the light to keep it working.
is there any way of fixing the strip and reattach the light to the strip again with out replacing the whole window? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #370450 8th Nov 2014 10:20pm
landroverdiver
If it's the foil that has a break in it, there probably is a product on the market that you can buy and most likely paint on. Try google.
I had the same problem, so simply ran another wire, tucked it against the window rubber and covered with black gaffer tape. It was pretty well ok at that, however I fitted internal grilles to the rear load area and fitted one on the back door, so it is completely hidden.
Post #370490 9th Nov 2014 7:07am
Ken B
Re: Rear window break light problems
I have exactly the same issue, my wire is now permanent and is hidden behind the rubber seal. A fix would be good though as the top half of my rear window heater element does not work so must be a break in the element but not bothered checking close up but could add to the job list. Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #370492 9th Nov 2014 8:42am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
This could be worth a try
http://www.halfords.com/motoring/garage-eq...ter-repair
Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #370502 9th Nov 2014 9:38am
Ken B
Nice One... never heard of the stuff but it is in stock at my local halfords so as much as i hate shopping with them off to grab some as that looks spot on for the job !
Thumbs Up Defender 90 TD5 County -
Post #370503 9th Nov 2014 9:41am
dorsetsmith
Post #370505 9th Nov 2014 10:00am
wyvern
Thanks all - I'll give them a try and report back !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #370550 9th Nov 2014 1:28pm
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
The reason the lights stop working is the break light draws to many amps and rear glass heated window is only designed to take low voltage through silver silk lines common fault on all defender they did mod 2013 on models but they burn out as well change bulb to led type just another JLR poor design
Post #371229 12th Nov 2014 10:41am
wyvern
That may be so Claire ... but the light was knocked when the light stopped working & I took the cover off - so slightly self imposed issues here Whistle
I found that the bulb had gone but when old bulb was removed, I found the metal strip was broken - hence the need to fix the thing!! Bow down Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #371503 13th Nov 2014 8:36pm
