Home > Technical > How to free off a seized caliper?
Page 2 of 2 <12
CFB
Bought a 'one man' basic bleed kit from Halfords, doddle to do but the pedal now feels softer than it did before Evil or Very Mad I didn't keep going for long with the pedal as after the first 2 or 3 pumps the fluid expelled via the clear tube had no obvious air bubbles. Should I have kept going longer? Andy
Post #370363 8th Nov 2014 5:34pm
munch90
the two man way is normally best , if you got a RUBBER that's RUBBER mallet it sometimes helps to give the caliper a gentle tap with it , helps to shake any air trapped up to the nipple
Post #370372 8th Nov 2014 6:07pm
jimbob7
Which "one man bleed kit"? If it wasn't the one that uses air pressure from a tyre your probably pi55in in the wind,Gunson Eezy Bleed is the one you want,a bit of ptfe tape around the brake reservoir in case of leaks,even then they can be awkward sometimes,the other type tend to suck more air back in thru the bleed nipple when you release the pedal. Pov.spec,ftw. 2006, 110,TD5.
Post #370480 8th Nov 2014 11:58pm
CFB
No not the pressurised one, this one just has a tube and bottle with a one way non return valve that is supposed to not let any air back in when you lift off the pedal. I'm sure it is now worse than before I tried to bleed it!! Andy
Post #370482 9th Nov 2014 12:08am
Page 2 of 2 <12
