Home > Puma (Tdci) > Reversing light
Page 1 of 4 1234>
Reversing light
Hi, do you chaps know where to find the fuse for the reversing light and also if i need to replace the bulb do you know what type it is? I came back tonight in the dark and have to reverse into our gateway however theres nothing from the reversing light at all i even tried R to Neutral and vise versa.
Thanks Thumbs Up
Post #37016 25th Jul 2010 9:21pm
MK
The fuse should be under the steering wheel (LHD at least) and it is red 10A and the bulb it is a normal 21W one contact. Puma 110" SW
Post #37017 25th Jul 2010 9:44pm
Thanks should be the same mine's RHD. Reason i ask is because there's little point point in removing the lamp just to check and everyone knows what they're talking about here. Thanks mate Thumbs Up
Post #37019 25th Jul 2010 9:51pm
Post #37035 26th Jul 2010 9:29am
MK
that should be the one. Do you know how to replace it? I guess yours is a non svx model. Puma 110" SW
Post #37039 26th Jul 2010 11:25am
Yes i do thanks mate. sorry about so many questions just checking as im as good as blind at night without that Shocked
Post #37056 26th Jul 2010 1:14pm
I have LED reversing light, it's really good and came standard!
Post #37075 26th Jul 2010 5:41pm
Brilliant aren't they surposed to last a long time? Although probably illegal for some stupid reason over here Rolling Eyes
Post #37078 26th Jul 2010 5:55pm
these are the same as the 60th anniversary model ...
Post #37080 26th Jul 2010 6:19pm
the bulbs i bought today have just arrived and have tried one with no result and also i have now tested the original bulb and that still works. I have checked all the fuses and they're all fine and i've also tried various lights on lights off ect ignition on and off ect whilst selecting reverse i still get nothing Confused The red fog light on the other side works fine on it's own switch but the reversing light just seems to be dead Big Cry
Post #37223 28th Jul 2010 2:52pm
mse
Try moving the connector when its on
Check the contacts are good (bulb and plug)
Switch the connector from the back of the reverse bulb to the fog lamp and vice versa Mike
Post #37231 28th Jul 2010 3:30pm
I shall have to try this only annoyance is i have to take the ladder part off to get the light out. I shall let you know. Failing this i think it must be reverse selector switch of which i don't have a clue about.
Post #37240 28th Jul 2010 3:55pm
mse
Quick trick.
Im not sure if you can get the bulb out on the puma from the back like you could on the v8. but you can't you can certainly disconnect the unit.
So the side you have accessible take to the other side and test the holder there.
Obviously you can go for a multimeter across the pins aswell.
A flexible screwdriver may help to get the screws out to slight the fitting off? Mike
Post #37242 28th Jul 2010 4:02pm
mse wrote:
Quick trick.
I have tried swapping between fog and the reversing light both work on the fog light connector to the reversing light bulb and holder is working fine i have also tried moving the connector about no joy. I have a multi meter how which setting do i check with? it's digital. As i don't want to blow anything. the reversing light bulb and holder IS working on the fog side just not on it's proper side.
Post #37245 28th Jul 2010 4:21pm
mse
If the reversing light connector and bulb work on the fog side (does the fog work on reversing side?)
Has to be a fualt from connector back. First think to check is that you are getting 12v at the connector - wire the multimeter up to the connector (probe in each side) set the right voltage reading and turn on.
Next if you get 0 there recheck the fuse but if your multimeter tests for continuity fast way is set it to it - exposed contacts one either side and test.
If the fuse is ok (check all just in case) and the connector is still 0 have a quick look for faults at the socket and then the loom 30 seconds before driving to the dealer with a gift (your car) for them! Mike
Post #37246 28th Jul 2010 4:33pm
Page 1 of 4 1234>
