![]() | Home > In Car Electronics > Upgrading rear speaker size to 5.25"+ |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
I fitted a pair of 6x9s in mine, works well and good sound.
not the greatest pic but you get the idea... ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Looks good Dave ... But fails on the 'Want to keep in same place' criteria
good point! reminds me of school again....
"must read the question!" ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
6x9's are generally best kept as separate in their own right on a stereo / 2 Chanel Amp set up.
Keep the four speakers as your regular set up. If you enlarge the holes you should be able to fit speakers straight in without rings. Rings look hideous I'm and major the speakers sit proud. On a Puma it's the OS that has the tightest rear clearance but providing the speakers don't have a massive magnet on the rear then it should be fine. Any larger and the speakers will probably all need amping as the HU won't be able to produce the power and it'll overload it and run very very hot. |
Mazzaman32 Member Since: 24 Apr 2014 Location: Kent Posts: 20 ![]() ![]() ![]() |
Many thanks.
I'm going to try the 5.25" and order spacers (just in case) as I'm going with Focals and based on the pair I fitted in the front they do have fairly large magnets. Will post the results. cheers! |
... Pov.spec,ftw. 2006, 110,TD5.
Before you do any cutting do some careful checking, you might be able to fit them slightly towards the gearbox tunnel on both sides.
That will at least mean on the OS the magnet on the rear will keep away from the heater duct / pipe more there. As mentioned in another thread, also be careful of your power requirements from the HU and new speakers. |
A brief post just to conclude that I upgraded the original 4" rear speakers to 5.25" today - I had to enlarge the existing hole slightly but a 2min job using a jigsaw. In total about 2hrs to remove speakers/apply Dynamat to the panel behind (using the Dynamat speaker kit which was perfect for this area) / enlarge the existing holes and replace all trim.
V good improvement over the original 4" LR speakers whilst retaing the same speaker positions and without the need for a bespoke speaker enclosure / running new wires etc. Hope it helps anyone who wants a little more from their rear ICE without significant modification. ![]() ![]() Click image to enlarge |
Looks neat.
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
only have 2 speakers, will have to ask Santa for some bigger ones to go in the back!
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Just fitted Hertz DCX170.3 (6.5") speakers on these Landcover rear panels in my TD5. Excellent upgrade
scotiach Member Since: 19 Nov 2014 Location: 5603 Posts: 36 ![]() ![]() ![]() |
epictrail did you fit spacers for the 6.5 inchers at the back?
Didn't use any spacers but had to jigsaw the mount opening wider. The speakers now fit flush on the front of the mount rather than recessed.
![]() Click image to enlarge ![]() Click image to enlarge |
excellent, thanks. they're pretty 'low profile' speakers depth wise at the back those ones. very nice install job.
