Home > Puma (Tdci) > Rough, uneven idle with smoke when cold... |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 545 |
Actually, I wonder if that could be an early indication of the battery getting weak (original battery on a 2009 2.4 Puma).
I checked with the Scangauge and voltage seems quite low, ~11.7V, before the engine fires up. Could that cause the glowplugs not to warm up the chamber enough, thus the rough idling and smoke at cold start? |
6th Nov 2014 7:51am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5736 |
I would check each glow plug first.
Andy |
6th Nov 2014 8:04am |
Shouldn't it log a DTC if a glow plug was at fault?
6th Nov 2014 8:09am |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
i have the same thing with my 90. not rough but an uneven idle when driving until it warms ups. i just assumed it was something to do with fuel flow and being cold.
10th Nov 2014 8:41pm |
Thanks all for your answer!
Not sure this is related, but the fitting the EGR blanking plate seems to help, or maybe it's the just the weather being warmer lately... |
11th Nov 2014 12:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20474 |
Sticky EGR no doubt, I got shot of mine.
Best choice imo, not cheap but cheaper in the long run. |
11th Nov 2014 12:55pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 700 |
Steve . when you blanked your EGR did you do it at the EGR or the exhaust manifold the other side? I blanked at the EGR and had issues with exhaust fumes. I was recommended to do it at the manifold side but not sure why. 2008 Defender 110 XS SW - M57N2 / 6HP28X
11th Nov 2014 1:23pm |
