Home > eBay & Bargain Spots > Castro actevo 2t oil |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Heads up anyone who uses 2 stroke in their diesel Wilko currently have on offer @ £8 a litre so if you pick it up cheaper than anywhere online atm have cleared out my local store 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
4th Nov 2014 2:50pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Possibly not as good as this D2.net deal from The Oilman... Rog...
The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
4th Nov 2014 3:01pm |
If you add postage it works out more 2008 110 2.4 XS Utility (Hagrid)
4th Nov 2014 4:13pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3643 |
EVO 2T
see below I have stopped using this in my BMW and now use the higher spec Power 1 racing due to the cat and dpf although I did not have any problem using this for the first 40k miles and 3 yrs. Note also there was a recall on this , see previous post due to water in it, caused a microlite to crash. I still however want a bottle for my chainsaw and strimmer Act>Evo 2T ________________________________________________________________________________ Applications ________________________________________________________________________________ Features / Benefits ________________________________________________________________________________ Specifications / Performance ________________________________________________________________________________ Storage ________________________________________________________________________________ Health, Safety and Environment ________________________________________________________________________________ Typical Characteristics Castrol Act>evo 2T is a modern, high quality 2-stroke engine oil for modern engines. Its Deposit Protection Formula is designed to provide continuous protection against the build up of carbon deposits on the engine and spark plug during use, keeping them clean to ensure fast and reliable starting. Castro Act>evo 2T is suitable for use in all 2-stroke motorcycle and scooter engines from both European and Japanese Manufacturers. It is designed for both oil injection and pre-mix lubrication, as per manufacturers' instructions, up to a fuel/oil ratio of 50:1. · High performance additives protect components from deposits in use · Good lubricity, protecting pistons from scuffing · Good protection against exhaust system blocking · Low ash formulation to reduce pre-ignition & catalyst deterioration · Designed for both oil injection and pre-mix systems up to 50:1 · Exceeds JASO FC and API TC All packages should be stored under cover. Where outside storage is unavoidable drums should be laid horizontally to avoid the possible ingress of water and the obliteration of drum markings. Products should not be stored above 60°C, exposed to hot sun or freezing conditions. Health, safety and environmental information is provided for this product in the Materials Safety Data Sheet. This gives details of potential hazards, precautions and First Aid measures, together with environmental effects and disposal of used products. Castrol International will not accept liability if the product is used other than in the manner or with the precautions or for the purpose/s specified. Before the product is used other than as directed, advice should be obtained from the local Castrol office. Page 1 of 13/03/2007http://fusion.bpweb.bp.com/bpglis/lubtds.nsf/FusionProductWeb/5E7170F57AD157E0802572020 ... ________________________________________________________________________________ ________________________________________________________________________________ ________________________________________________________________________________ ________________________________________________________________________________ The above figures are typical of those obtained with normal production tolerance and do not constitute a specification. ________________________________________________________________________________ Test Method Units Value SAE Test Method(s) Unit Min Typical Max Density @ 15C, Relative ASTM D4052 g/ml 0.8634 Viscosity, Kinematic 100C ASTM D445 mm²/s 6.5 6.9 8.0 Viscosity, Kinematic 40C ASTM D445 mm²/s 37.0 37.4 38.5 Flash Point, PMCC ASTM D93 °C 70 73 Pour Point ASTM D97 °C -45 -39 Colour ASTM D1500 1.5 This Data Sheet and information it contains is considered to be accurate at the date of printing. No warranty or representation, expressed or implied, is made as to the accuracy or completeness of the data and information contained in this publication. It is the User's obligation to evaluate and use products safely and within the scope advised in the data sheet and to comply with all applicable laws and regulations. No statement made in this publication shall be construed as a permission, recommendation or authorisation given or implied to practice any patented invention without a valid licence. The Seller shall not be responsible for any loss or damage resulting from any hazards or risks identified in the data sheet and which are associated with petroleum products concerned (provided that this disclaimer shall not affect any statutory rights of the Buyer of the petroleum products concerned). DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
4th Nov 2014 9:16pm |
