Home > Technical > Embarrassing noob question |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
you move it forward and back for High and Low (high being forward)
You move it left and right for difflock ON/off. (left being ON) |
4th Nov 2014 3:28pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1173 |
Thanks Mike.
Need to get my grips out and turn this thing then!! Cheers |
4th Nov 2014 3:30pm |
not sure ive explained properly but it doesnt turn. you will just pull the knob off it lol. if it wont move L/R F/B then the linkage could be seized.
4th Nov 2014 3:33pm |
I understand mate,
I would just like the knob to align up with its directions of use properly. Is it common for the mechs to seize up? G |
4th Nov 2014 3:41pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
I put a pair of those ally gear knobs on my 300tdi & could never get the transfer gear knob to line up,no matter how much I turned it.
4th Nov 2014 4:06pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
From looking at your picture the high/low gear knob isn't correctly aligned to the way the lever is operated.
The High / Low is in an H shape; | _ Low Diff | | _ Neutral Lock | | _ High I presume you're in High range at the moment. It should push forward towards the main gear selector to go into neutral and then again to go into low. Pushing to the left from High / Neutral / Low should engage the Diff Lock I hope this helps |
4th Nov 2014 4:13pm |
Maybe I should just unwind it till it lines up
Pop a bit of ptfe tape on the threads to keep tight? |
4th Nov 2014 4:14pm |
Or some thread lock.
4th Nov 2014 4:15pm |
Thanks for the diagram Paddy
I was playing with this earlier on and the selector is happy going side to side But not willing to go back n forward |
4th Nov 2014 4:16pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
try forward to back as you are moving very slowly, just as clutch is biting My 109 thread
my youtube channel |
4th Nov 2014 4:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
From stationary try clutch down, select first gear and keep clutch down - the move the transfer box lever up one into neutral. You should then be able to bring the clutch up even though your in first gear the transfer box is in neutral.
Then repeat this process again moving from neural into low but be prepared to move off as you are in low range and will also make more torque. To go back is the opposite process. I personally like to change on the fly so you want a low speed I.e. 5 to 10 mph and you should be able to slip righ across between hi and low. 98% of the time you'll never need low box and it's not for on road use, only low speed pulling, manoeuvring or greenlaneing. Take more care going from high to low as it's much lower gearing. Any change should ideally be under no load but that's not always possible or a necessity. You'll soon get the hang of it, you should never need to force it. |
4th Nov 2014 4:53pm |
Thanks for the explanation lads.
I wont get a chance to have a look at it till morning, I'm takimg it to work tomorrow to allow one of the technicians to check the whole thing over for me. Fingers crossed that I havent bought a squib! G |
4th Nov 2014 5:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17467 |
It's probably stiffened up through lack of use. Sometimes a long fast run to get the t-box really hot can help.
4th Nov 2014 5:54pm |
Tried the, selecting hi/low while moving trick and everything seems good
It was just stubborn while sitting stationary. But all appears well. Thanks for the tip G |
4th Nov 2014 6:21pm |
