Home > Technical > TD5 Relative Compression
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Hi All,
Just ran a relative compression test on the TD5. Going to do a manual test tomorrow on all cylinders, but for now ... what do people think to the readings. Look reasonably tidy to me, but just wondered if there were any expert eyes that could take a look. The random spikes are most likely due to the fact it's not quite a Pico Wink ... So not quite as refined!
I do also have a video showing the white smoke out of my PCV pipe as well as one showing injector balance. This is all part of my rattle problem I'm trying to resolve. Trying to rule out any major engine issues!
Those videos though are currently uploading through my phone network so may take a while Sad ...
Relative compression shots:
(Taken me hours to upoad those damn pics ... The upload on this thread is broken and no where seems to work lol!)
Post #367390 26th Oct 2014 9:43pm
taazzukcb
Injector Balance Vid:
Post #367399 26th Oct 2014 11:07pm
taazzukcb
PCV Pressure Vid:
Post #367401 26th Oct 2014 11:08pm
Fatboy Slim
Wales
Injector balances are really a bit of a waste of time unless you've got a dead miss somewhere, seen many people lead up a very expensive garden path with them on a motor that in actual fact has nothing wrong with it. Seen much worse blowby than that as well if I'm honest. Whats the noise your trying to track down?
Post #367593 27th Oct 2014 7:42pm
taazzukcb
I've got a rattle that sounds diesel knocky to me. There's the potential that it's Clutch/DMF, but to be honest. I dont get any other Clutch/DMF symptoms except maybe a little slip when really pushing her at the top, but it's not obvious if so ...
I have just done a Manual Compression Test on each cylinder using the Injector port. Whilst the Dummy Injector tool is good, it's a bloody nightmare to get seated well and lead to several duff readings ... IMO it needs a little redesign to use the outer walls to get a straight fit!
Here's the results ... (All in BAR) ...
Cyl 5 4 3 2 1 -> Front
27 30 26 29 28.5
28.5 30 26 27 25.5
N/A 28.5 30 31 31
All a bit sporadic tbh ... They all went 1-5 and the third run I lost battery after No.4 so no last reading for 5.
What do people make of them?
Post #367657 27th Oct 2014 10:17pm
Fatboy Slim
Wales
3 quick questions,
1- Does it start first flick of the key in the morning or do you have to bump start it for 5 miles with another vehicle?
2-Does it smoke like it's running on coal at full load?
3-does your noise disappear when coasting?
Post #367817 28th Oct 2014 6:36pm
taazzukcb
1. Starts first flick fine. Had trouble when the injector seals went but fine since.
2. Never noticed much if any smoke. Can't see out the back of mine at all so not 100% on this but even when she's pretty much foot flat on the floor there's nothing obvious out the wing mirrors. Small waft of white sometimes on initial start up.
3. I did origionally think so yes. However just recently I have wondered if its very very slightly there even coasting down a hill for instance on the clutch. But it might just be me thinking there's something very very slight!
You sound like you have a theory?
Post #367820 28th Oct 2014 6:45pm
Fatboy Slim
Wales
I have mate and I hate to say it after all the work you've put in but I wouldn't say there's much wrong with it in truth.......
Post #367822 28th Oct 2014 6:49pm
martinfiattech
A little off topic I know but,
On viewing your first video clip I noticed your using a Delphi diagnostic program. I`am looking into buying one of these or at least a clone copy. I just wondered how you find it, and what does it cover i.e. will it give access to a 2011 my 90.
As for your injector balance all looks ok may be you have a slightly dribbling injector / spray pattern issue. Perhaps a course of fuel cleaner might help. Excuse the spelling I`am better with spanners and wires.
Post #368751 1st Nov 2014 3:21pm
taazzukcb
It took them a while as it seems mine were down the priority list, but it seems one of my injector solenoids was well out of tolerance.
As to the Delphi, yep, will read your Puma 90. Will read more info than it does for the TD5 as your's conforms to OBD standards. Nice units indeed!
Post #368799 1st Nov 2014 6:04pm
mk1collector
Has it sorted the noise then?
Post #368847 1st Nov 2014 8:48pm
taazzukcb
Dont know yet. They still have them. They're trying to source me another injector which they can then refurb but it isn't proving easy at the moment. Even sources of new one's are quite thin on the ground at the minute apparently.
Once everything is back I shall endeavour to let you know mk1! Trucks out of use until then (obviously lol)!
Post #368856 1st Nov 2014 9:03pm
mk1collector
Thumbs Up cheers
Post #368910 1st Nov 2014 11:25pm
