Home > In Car Electronics > 12v supply from the tow bar? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
What type tow socket does the Defender have?
You might find it easier to use the cig lighter socket and get a switch capable of taking the current in-line. |
1st Nov 2014 11:02pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Single socket. Old type with big pins.
1st Nov 2014 11:05pm |
12N I assume which means there is no useable auxiliary power supply there.
Only 12S would supply your needs and even then you'd still need it switched. For the clay trap do you need a constant live or some way of switching? |
1st Nov 2014 11:08pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Could you not use the 12v supply for towing electrics that is in rear panel of truck? Purple wire behind speaker panel.
Andy |
1st Nov 2014 11:13pm |
none of the standard wiring will be heavy enough amp rating for a electric clay trap
used to have a lot to do with clay traps you would want say at least 50a fused supply with some like a Anderson plug on it ,BUT check on your trap specs as different makes could be different amp rating needed single stack bowman trap is fused at 30a , 6 stack 40a , towing electrics fused at 10a normally still easy to do , plenty of places to run 50a fused cables to the rear on any defender , doubt you would need extra battery as a trap motor only running for a few seconds each time when re cocking thrower arm or turning carousel. ( unless your running a roaming trap then you might use quite a bit of power from battery ) |
2nd Nov 2014 8:06am |
Thanks.....think the andy plug is a good idea. I can do that like a winch power supply with an isolator and fuse. Thanks for the advice.
2nd Nov 2014 6:21pm |
