Home > Technical > clutch post
jst
clutch post
i am likely to be having a blonde moment!
Where did the post ref clutch noise go, specifically the one that mentions the rattle when you turn it off without depressing the pedal?
Mine is doing it very badly, gear change is also harder than it used to be and the pedal is alot heavier than it used to be, could do with knowing what to say to the dealers to get them to sort the revised clutch release plate as its been in already and apparently ' thats normal sir'................!
It has also started making a noise, more pronounced when cold, in low 1st or rev when under slight load. (No its not the anti stall!) Dealer couldn't replicate this noise! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #36829 23rd Jul 2010 6:22pm
mse
What you have said is all you should need to say.
Try capturing it on video, ask for the service manager to come out for a ride - just keep on it Mike
Post #36831 23rd Jul 2010 6:30pm
jst
i have already said all that and its been in for 2 days - NFF! they are all like that Sir! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #36874 24th Jul 2010 8:42am
mse
You need to keep working on them - point them in the direction of a service action, arm yourself with a video of the problem, highlight others you know with the problem (use me if you like)
I have been there - it took 2 visits to the first dealer for the 1st clutch and maybe 3 or 4 for the second clutch Mike
Post #36875 24th Jul 2010 8:50am
jst
Thank you. Rest assured i won't let it rest.
I have already demo'd the noise to the guy who collects the vehicle who is one of their sales guys. not ideal but then its a trek to the dealers!
what was the service action number? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #36878 24th Jul 2010 9:10am
mse
starts here:
506000 Clutch Concerns
I have it if you want Mike
Post #36883 24th Jul 2010 9:55am
jst
any chance you could email it over please.
james@4x4adventures.co.uk Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #36890 24th Jul 2010 11:00am
mse
done Mike
Post #36914 24th Jul 2010 6:19pm
jst
Cheers MSE, they fitted a new clutch release cover today - apparently - will see when i get it back! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37872 10th Aug 2010 8:51pm
mse
hope it works Mike
Post #37914 11th Aug 2010 3:34pm
MK
since a 1000 km I got a high pitch rattle (clink-clink-clink) coming from the clutch area, especially when the clutch pedal is depressed. The frequency matches with engine revs somehow.
I imagine these are loose springs from the clutch plate. I do not have any other symptoms. Anyone got the same? this clutch assy is 4000 km since last change Mad Puma 110" SW
Post #40613 16th Sep 2010 10:40am
jst
mine didn't do that when the engine was running. do you get anything noise wise when you turn if off with the clutch up?
in the end they fitted tow new release covers to mine seems sorted now. clutch is lighter again too. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #40643 16th Sep 2010 3:01pm
