![]() | Home > Technical > 300tdi Not Starting - click click |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
I had the same type of issue with my 200TDI. Turned out to be cheap battery clamps from China, they looked ok but the screws holding the cable in the clamp would work lose, or at least once i changed them out for decent ones I seem to have had no issues...........probably fail to start now i've typed this
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Take it out and use jump leads to test it all works direct from the battery. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
The spider that you mention is fitted to Discovery 1's and can cause starting problems. As DaveT says pull it back of and couple it up to a battery and run it on a bench. Give it a spray round with electrical contact cleaner
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
does the motor turn with direct feeds? sounds like solenoid working but motor stuck Cheers
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5116 ![]() ![]() ![]() |
Also check you have a good earth from the battery. A quick way to do this is place a jump lead on the negative terminal and the other clamp on a good earth point engine, chassis etc.
MachineGreen Member Since: 28 Oct 2014 Location: Canada Posts: 7 ![]() ![]() |
Very strange. I pulled out the starter again. Bench tested it and could only bypass the solenoid to get the starter moving. I removed the solenoid, looked at it and put it back on, bench tested it again and it worked with the solenoid. Installed it and it works fine. Odd. The only thing I did was 'think' it would work this time! lol
Thanks for the info... now on to all the other problems. |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
We don't have problems only challenges ![]() We all like a challenge hence owning a Land Rover ![]() |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 ![]() ![]() ![]() |
Hey machinegreen
Where are you in Canada? I have an 84. 1110 with a 300tdi. We should compare notes..... Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
