Home > Maintenance & Modifications > fitting an internal single hoop roll cage in a D90
Monmouth
Wales 1990 Defender 90 300 Tdi SW Firenze Red
I've got a hoop to install in my 90, will i need to remove the roof from my station wagon to enable the fitting? 1990 Defender 300TDi
Post #367900 29th Oct 2014 12:17am
Depends on how big it is.....
And how long the legs are, if it has spacers between the bar and the inside of the roof, all sorts of things.
Post #367998 29th Oct 2014 12:01pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Probably... it depends on the design, as above.
IF you can't do it without then bear in mind that you don't need to unbolt the roof as such. It's simpler to unbolt the windscreen hinges (if you have proper windscreen hinges, even better, you just need to undo the stay bolts), unbolt the bottom of the rear sides form the back body (a few nuts on each side - 3 in most cases) and then you can simply lift the rear of the roof a few inches in one piece complete with headlining and trim. A block of wood at each side to support it and you can fit the hoop then lower it back down again.
That way you don't have to break the seal between the windscreen and roof and don't have to remove the headlining. If you don't have "proper" hinges at the bottom of the windscreen, make sure it doesn't slide forwards off the bulkhead when you lift it at the back. http://www.yorkshireoffroadclub.net/
Post #368026 29th Oct 2014 2:19pm
