Home > Camping, Caravanning and Holidays > How to secure demountable camper unit to HCPU tray? |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Every piece of camping equipment has been well thought out by me.Things like the 2 seats, table and the cooking equipment can be fit in one "little" rucksack.
Curious how it all turns out when you're finished. Had a look at Lelycampers, but my god! They are huge... |
29th Oct 2014 10:34am |
DemountLandy Member Since: 19 Nov 2014 Location: Dorset Posts: 2 |
I picked up my new Northstar demountable in September 2011 and as in interim measure used ratchet straps onto my tree sliders at the front and onto the rear crossmember at the rear. Ten thousand miles and many off-roading trips later I'm still thinking about a permanent solution!!
The straps have worked fine but do look rather temporary. The camper has not moved more than 12mm even during some relatively extreme off-roading and axle twisting. I am, however, going the eye and turnbuckle route. At the front onto that little flat bit at the rear corners of the cab which will be braced with tensioned rods down onto the chassis - at the back I'm still not sure yet but there are several strong points available! I certainly would not mount the camper just to the tub as they do on the Jap type pickups with steel tubs. My previous mount, a Mitsubishi L200's chassis twisted so much there really wasn't a viable option. My Defender's chassis is over twice the section and twice the gauge so probably in excess of four times as rigid. Twist is, therefore, not an issue. Martin Click image to enlarge |
19th Nov 2014 9:25pm |
