![]() | Home > Events > Daily Driver Event - thats rights for your 07MY vehicle!! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
The last daily driver event for the year will be on 4 Oct 08, again at Wellington.
If you missed the last one there are some details here: http://www.4x4adventures.co.uk/_main/_reports08/080329_ddc.htm The rules and regs from last time remain the same ie: There will NOT be a class system but there will be some vehicle restrictions. These are primarily: 1. Your Vehicle must have current road tax, Insurance and an MOT. 2. Maximum Tyre size of 33" tall (255/85R16 equivalent). 3. No Simex Style tread patterns, eg FEDIMAs, INSA TURBOs etc. 4. All vehicles must have suitable front and rear recovery points. A standard fitted towbar is adequate for a rear recovery point. Front recovery points should be a minimum of JATE rings on each chassis leg if a dedicated suitable winch point has not been fitted. Lashing eyes are NOT acceptable. All tow hitches, whether front or rear mounted, should be bolted to the vehicle (not welded) and must be fitted with spreader plates.) 5. Kinetic Energy Recovery Ropes (KERR) are NOT permitted. In addition you must comply with my standard rules and regs detailed here The day is designed to be fun and with luck we will have better weather than last time around! I know it was a little wet by lunch time! The cost is £45 per vehicle, you must pre-register to enter and you can do that by following the links here; http://www.4x4adventures.co.uk/_main/gener...event_id=1 or emailing me for details. Those registered will receive directions, timings and scrutineering instructions via email approx 1 week before the event. If you wanted to make a weekend of it then why not do the event on the Sun then join us for an escorted drive around the site on the Sunday - camping can be made available, plus there is an official site just down the road or B&Bs if you prefer with good rates - email for details. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
