![]() | Home > Maintenance & Modifications > Rear brakes Sticking on TD5 |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
This has happened about 3 times now.
After parking, I have noticed some drag on the car, drivable in low gears. Anyhow, once around the block and the brakes free up. Today managed to get under the truck and found rear brakes very hot - enough to burn finger on offside, near side also seemed hot, but didn't fancy two blisters. Ideas guys, is it mechanical or something else? (only happens after parking) ![]() Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 ![]() ![]() |
Strange i would checkout transmission brake ????
I originally thought handbrake, but I don't generally use it as have had problems with that as well (although ok at the moment).
Today was the first time I had chance to get under car when it had happened. Definitely rear brakes as 'red hot' front brakes just warm. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Very common problem on rear callipers. If you have a look i would say the pistons in the calliper are corroded. Either buy 2 new callipers (always replace in axle pairs) or 2 new piston and seal kits (SEE500140)
Zinke,
Thanks for info. How easy is it to service pistons? Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
The seals aren't too difficult to do. Just need to be very clean when you do it.
I always find it best to shot blast them and paint them while your at it. Another thing you can consider is stainless steel pistons. |
