Home > Maintenance & Modifications > 4x round drl's
Page 1 of 3 123>
Likeomg
4x round drl's
gonna make up a copy of the kahn bumper while I'm on my next 4 month trip, getting a load of stuff colour coordinated for the car so will get the bumper done also,
thinking about going with this kit
http://www.outbound4x4.co.uk/shop/exterior...bumper-kit
any one any other thoughts on good round drl's?
Kahn one for any interested - retail was like £1300 last time i checked hence DIY
Post #366478 22nd Oct 2014 5:47pm
munch90
I got the 2 drl kit , can't fault it , looks neat fitted , been good no problems with it
got just the kit and fitted myself , all easy really , big hole cutter needed , take your time ( slow drill needed )cutting/drilling the hole and best to use some cutting oil to help protect cutter
Post #366482 22nd Oct 2014 5:59pm
URBAN TRUCK
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Hi,
The DRL's are great quality and look fantastic with the recess, We have the DIY Kits available in our store and all you need is a 79mm metal hole saw. If you don't fancy the install I have prebuilt recess DRL bumpers on the way in about 7-10 days time using these exact lights.
Price are as follows :
Single DRL DIY Pack (Contains 2 lights and fittings) - £99 + VAT
Double DRL DIY Pack (Contains 2 lights and fittings) - £198 + VAT
If you want the prebuilt version (about 7-10 days time)
Single DRL Bumper £199 + VAT
Double DRL Bumper £299 + VAT
Here is an example of 2 lights installed :
Post #366488 22nd Oct 2014 6:10pm
666PXX
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
The lights look great, but are a Censored to fit - will easily take 3hours to fit! Confused
Post #366510 22nd Oct 2014 7:41pm
URBAN TRUCK
I Agree 666PXX … The fitting isn't easy at all and even more so for a double DRL because there isn't much space and the cuts have to be mm perfect.
Thats why we are getting the pre built bumpers with 2 and 4 lights pre installed.
Regards
Simon
UT
Post #366511 22nd Oct 2014 7:45pm
munch90
well I didn't think it was much trouble fitting / cutting the holes , you got a template for marking etc , like I said cut holes slowly with cutting oil
got a cutter from swcrewfix
Post #366514 22nd Oct 2014 7:51pm
Mean Green
Are there any options to fit driving lamps rather than DRLs in the recess' ?
I currently have a pair of Cibie Oscars on an A-bar but am starting to think that it looks little dated and like the 'clean' lines of the UT machines (in particular) but still want additional high beam lighting.
Post #366518 22nd Oct 2014 8:05pm
URBAN TRUCK
I was thinking of adding in Driving lights.
Just sent an email to our supplier to see if we can do a mix .
back to you soon.
Regards
Simon
UT
Post #366519 22nd Oct 2014 8:10pm
Bristol 90XS
I'd be interested in a bumper with DRL and driving lights to aid full beam!
Ideally would like to remove bumper, get it galvanised and then re-fit once UT had done all fitting etc first, would this be possible?
James
Post #366529 22nd Oct 2014 8:50pm
Bristol 90XS
Oops double tap on iPad...
Post #366530 22nd Oct 2014 8:50pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Rigid Industries driving lights set into bumper from IRB
Post #366546 22nd Oct 2014 10:00pm
Likeomg
not a fan of the above, my led bar covers my extra lighting needs so these would be a drl only for me, and as my current bumper is starting to flake on the bottom i might as well try drilling it myself then having it powder coated if it doesn't work out ill just buy a bumper from urban.
Post #366562 22nd Oct 2014 11:39pm
defender4
Sure, I was replying to the Mean Green and Bristol 90XS queries/comments about driving lights in the bumper.
Post #366582 23rd Oct 2014 7:33am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Picture for Mean Green and Bristol 90XS
Rigid Industries Dually D2 driving lights and Amber Fog lights recessed in a D44 bumper
DLRs are within side lights
Post #366760 23rd Oct 2014 8:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
i like the round drls they look good but would want them built into a heavy duty stainless bumper coated in black ?
Thumbs Up 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #366779 23rd Oct 2014 9:30pm
Page 1 of 3 123>
