![]() | Home > Technical > Urgent worried transfer box question |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Sounds like the speed transducer. Has the new transfer box got a centre diff lock as I thought only the models with traction control had no speedo drive as it came from the abs reluctor ring signals. 02' 110 TD5 Double Cab Rebuild Thread
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
It sounds like you are describing the speedo sensor, a hole for which is not fitted to the Disco2 box.
It's just one of the things I also learned about the so-called "straight swap" between the Def and D2 box ![]() You will need to swap the housing and brake drum etc onto the D2 box. ![]() ![]() |
Can I ask martin, is it just a straight unbolt and swap over or is it a more involved job?
Cheers Ray |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Undo the housing complete with the output shaft and swap the lot over. Easy peasy. You'll also need to swap the front flange as the D2 one is different. Easy peasy again.
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
On a side note, keep me posted on the DMF!
I have a clutch and DMF on the way so will check mine out next week. Also tempted to fit a D2 box to! Sounds like it's just easier to swap the internals over! |
Nope, nothing falls out. Done many of them, use a good quality sealant on the mating faces. 20 mins work tops.
![]() ![]() Taazz, I'll keep you posted. Hoping to get it back Friday. Cheers Ray |
skoller Member Since: 27 Oct 2011 Location: australia Posts: 7 ![]() |
Speaking about the speed transducer, does anyone know if its sealed with an o ring or gasket to the transfer box. Mine is weeping a bit of oil and would like to know a little bit about it before I try to fix it. I think I can get to it by removing the plate between the seats.
Yep, see below:
![]() ![]() Click image to enlarge |
Looks good. Thank you
All done and fitted and seems good so far
![]() Thanks again for the help Ray |
