Home > Technical > re fitting exhaust
jimbob7
re fitting exhaust
How much of a gap is there between the front (cat) pipe and the middle silencer,mines about 4mm,is that normal??I've cleaned both faces but it wont go any closer.
cheers Pov.spec,ftw. 2006, 110,TD5.
Post #366386 22nd Oct 2014 9:50am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
IIRC the seal is made when the pipes are joined together, with one sitting inside the other, not on the actual flange that the bolts go through. It'll be obvious if this is the case because the pipe will extend beyond the bolt flange. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #366405 22nd Oct 2014 10:52am
jimbob7
Yeah the pipe does extend beyond the flange,i just thought the flanges would be closer (or fit flush) than they are,I've used sealant anyways,cheers bud Thumbs Up . Pov.spec,ftw. 2006, 110,TD5.
Post #366422 22nd Oct 2014 12:07pm
munch90
the joint will be tapered to seal
Post #366476 22nd Oct 2014 5:41pm
jimbob7
/\/\/\,yeah tapered, just thort the flanges would sit closer together Thumbs Up fyi, I used Blo seal,about 5 delivered off Amazon. Pov.spec,ftw. 2006, 110,TD5.
Post #366605 23rd Oct 2014 9:27am
munch90
used blo seal for years never had a problem with it
Post #366614 23rd Oct 2014 9:57am
