Home > Technical > Transfer case swapping - questions
Page 2 of 2 <12
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Take a photo of the orientation of the hi/lo mechanism before you take it appart,so when you put it back you can see it goes in the corect way round.
Post #366222 21st Oct 2014 5:24pm
excossack
Cheers will do.
I hope after all this the noise I have goes away. But if not on the plus side, I have a t/c with 50k less miles on it, I will have lower gears, will have replaced the bearings in the front and rear outputs and have new gaskets.
The current TC has some play in the front output bearing and also a leak from the rear of the TC. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #366425 22nd Oct 2014 12:37pm
Page 2 of 2 <12
