![]() | Home > Puma (Tdci) > Grumbling noise when slowing down. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5866 ![]() ![]() |
Check front diff, if early 110 it will have the weaker two pin (stupid name as has one pin) diff init.
You can check it if you use a torch via the filler hole. This is what I found ![]() Click image to enlarge Spot the one pin, that now is a two pin. Apart from that grease props and see if it alters vibration. |
Lloydy 7 Member Since: 13 May 2014 Location: Macclesfield Posts: 3 ![]() ![]() ![]() |
Thanks Andy, I'll have a look. Have greased props before posting this but no effect.
