Home > In Car Electronics > DAB roof aerial
Page 3 of 4 <1234>
barbel jim
Do you now get dab at home as well Bob? Is it worth all the expense and effort ? Thanks for all you reviews and trials I'm sure it will benefit many Thumbs Up the bit I find most appealing is the stock look Thumbs Up
Post #365972 20th Oct 2014 7:46pm
bob neville
Hi Jim
I get DAB at home now without any issues Thumbs Up
As we live in a marginal area I was not expecting much but can get 99% of the stations we are supposed to get loud and clear.
The time and effort were worthwhile and I am very impressed with the results. Aerial problem aside, the installation is very easy, you just need a switched 12v supply to the amp from the radio. I tapped into the switched radio input power lead and that is it. Connect the plugs up (correctly !) and you are done. The amp is small and fits to the side of the radio in a Tdci and looking at the TD5 there will not be issues tucking it away in the dash.
I am glad I gave it a go as if it did not work everything could easily be reversed.
2013 Defender 90 CSW - sold
Post #365977 20th Oct 2014 7:58pm
barbel jim
I'll put it all on my Crimbo list, but alas I think Santa's a bit poor this year Whistle
Post #365979 20th Oct 2014 8:04pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hey bob do you think the splitter improves FM reception i.e. does it amplify both Fm and DAB signals?
Post #366002 20th Oct 2014 8:52pm
bob neville
It amplifies both.
I did a quick test on FM with the splitter and then just the aerial plugged in directly and reception was far better with the splitter connected Thumbs Up
Post #366017 20th Oct 2014 9:25pm
barbel jim
Just moved up the crimbo list to needed !! Whistle
Post #366023 20th Oct 2014 9:41pm
kmac
Thanks Bob, now I need to decide;
1) is my original antenna broken ( I think it might be - the central part of the coax cable is very fine indeed and susceptible to breakage)
2) if it is - do I get a Bosch autoflex or a Dab + FM/AM antenna and "future proof"
3) if the original isn't broken, I could get a splitter
Post #366298 21st Oct 2014 10:08pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Bob - you still happy with your DAB splitter ?
Are you running the standard LR rubber FM aerial or did you replace with a newer/better one ? ... my FM reception is pretty rubbish and the windscreen DAB isn't much better ... I have bought a powered splitter from DAB on Wheels but am wondering if a new FM aerial would be the way to go at the same time ?
rgds
Jon
Post #447283 19th Aug 2015 9:06am
bob neville
Hi Jon
Just moved the complete set up from the TDCI 90 to the TD5 as the TDCI has gone.
TDCI had a standard LR aerial that was perfect for the splitter and DAB. The TD5 is running an Entreq flexi and this is also fine with the splitter and DAB.
If your FM is rubbish on the LR aerial it sounds like you may need to replace it, I had this problem originally and it was the actual cable that was damaged.
I am actually getting better DAB reception with the splitter and Pioneer radio than from vehicles that have DAB as standard - work that one out !!!
Post #447315 19th Aug 2015 11:34am
jont
Sounds like a plan - best place for an Entreq flexible aerial ? ... does Brendan still stock them ?
Jon
Post #447317 19th Aug 2015 11:44am
bob neville
I would start with Brendan Thumbs Up
Post #447323 19th Aug 2015 12:08pm
I'm going DAB only in my 90, I have an Alpine Bluetooth stereo, though the bluetooth is 'ropey'. So I want DAB only, no bluetooth and a decent external aerial. I take it you don't need the splitter if you don't want FM?
Post #447349 19th Aug 2015 1:34pm
bob neville
Not 100% sure of the answer to that.
Best bet would be to contact DABONWHEELS, they offer really good advice.
Post #447394 19th Aug 2015 3:55pm
Will do, cheers Bob.
Post #447395 19th Aug 2015 3:56pm
jont
IIRC the 'splitter' uses the FM aerial to receive and convert the DAB signal - so unless you fit a DAB-only aerial then you will need a splitter for a better signal (certainly than the stick-on window loops if accounts are to be believed) ...
Am just waiting on Brendan to let me know about a better FM aerial price Wink
Jon
Post #447406 19th Aug 2015 4:30pm
Page 3 of 4 <1234>
