Home > Puma (Tdci) > What this for?
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
What this for?
Hi All. Just been having a noisy around my new utility. Found this relay in the battery box.
Looks to me like a botched effort.
Cable exits top of battery box by seat mechanism and under floor mats then up thru centre console. Pete Bell found this when he was working on it, unknown to him what is was as it's not on his utility.
Regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #365644 19th Oct 2014 1:23pm
Fifth Horseman
Relay and fuse for the ignition switched supply to pin 6 of the 12S (or pin 10 of the 13 pin) tow socket.
Or relay for front auxiliary lights.
Its amazing how many different locations the battery box these relays are fitted considering the fitting instructions show where to mount them.
[edit] Looking at the wiring colours off the relay, it is for the tow electrics, kit fitting instructions https://www.defender2.net/gallery/albums/u...20TDCi.pdf
On my 110 whoever fitted the kit had not even cut the tapes to make the loom the correct length Shocked
Post #365649 19th Oct 2014 1:46pm
That looks to be in much the same position as the relay for my towing electrics - LR kit & fitted by a main dealer.
Post #365898 20th Oct 2014 2:35pm
Mynstral
Thanks for your replies. Still looks like a botched job to me as it's very awkward to remove jack handle etc.
Post #365927 20th Oct 2014 4:47pm
munch90
main dealer workmanship !
Post #365928 20th Oct 2014 4:53pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
That's why I try and do all of my own mods and maintenance.
The fewer dealer visits the better.
Post #365931 20th Oct 2014 5:03pm
If your vehicle is brand new, and dealer fitted, I'd go back and grab the service manager by the ear or the nose and drag him out to have a look at it, then demand that they send the kid who originally fitted it back to the creche and get a grown up to do the job.
Post #365935 20th Oct 2014 5:33pm
Fifth Horseman
And to think when I bought the wiring kit for my previous Defender my local dealer had the cheek to say "it's better to let us to fit it in case of problems later".
Needless to say I fitted it myself.
Post #365946 20th Oct 2014 6:02pm
Fatboy Slim
Wales
Trouble with the standard of main dealer work is the management not the lads in the shop. All Mr dealer cares about is completing the job in the shortest possible time with the least amount of expense. Get the fitters to do the job in half the book time but invoice the full hours to the relevant cost center. Looks good on the spreadsheets you see..........sad but very true.
Post #365956 20th Oct 2014 6:15pm
martinfiattech
Or worse it could have been fitted by a sub contractor, (some of them) can be right cowboys.
There`s a lot to be said for doing the job yourself, I had to re do the alarm on mine as scotch locks on a ignition feed aren't a good idea. It cost the previous owner £ 450.00 to fit the alarm.
Edit,
I`ll agree with fatboy slim, the dealer see`s pdi and towbars as a money earner to be done as quick as poss.
This I know only too well. Excuse the spelling I`am better with spanners and wires.
Post #365993 20th Oct 2014 7:37pm
