Home > In Car Electronics > Battery connections
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Battery connections
Does anyone know if there is a neat and simple way of making direct connections to the battery with multiple cables. I have a few things wired direct but they are all just on connectors bollted in and its a bit of a mess to be honest!
Post #364950 16th Oct 2014 1:30pm
kipperthedog
Post #364956 16th Oct 2014 1:47pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
That wouldn't be enough for a winch or jump leads (via an anderson cnnesctor under the bonnet) though would it?
I have been looking for the same myself, the Discovery 4 has a bus bar type strip of metal coming off the post that everything bolts to, I just can't find anything remotely similar anywhere. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #364960 16th Oct 2014 2:51pm
munch90
no where near heavy enough for winch etc
really you need to be looking at marine industry for the type of thing you want
Post #364962 16th Oct 2014 3:02pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
You could fit something like I have 👍
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #364963 16th Oct 2014 3:06pm
sparkylee
All got from Tim sponsor on here Thumbs Up It's good to be back from the dark side
FFRR 4.2 vogue
Post #364964 16th Oct 2014 3:07pm
kipperthedog
Op didn't say anything about a winch.......
Post #364982 16th Oct 2014 4:26pm
munch90
third post down
mentions winch
no good for that
sparkylee's looks the thing to have
Post #364983 16th Oct 2014 4:29pm
kipperthedog
Oh yeah, but the OP doesn't. So the product might suit post one, but not post three, which followed my post. I am all caught up now!
Post #364986 16th Oct 2014 4:43pm
Eduardo
Something like that from Blue Sea...
Can handle up to 600A...
http://www.amazon.com/Blue-Sea-Systems-Pow...ea+bus+bar
There are others with more bolts to handle up to 150A
http://www.amazon.com/Blue-Sea-Ampere-Comm...ea+bus+bar Eduardo
Post #365056 16th Oct 2014 8:00pm
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Sparkylee, that is a neat solution. Have you re routed the main negative lead to the bus bar, and then added a link cable from the bus bar to the battery? The battery terminal connector on my negative lead does not make it easy to connect any additional leads ( unlike the positive lead connector ). I guess I would just need to cut off the existing terminal connector and crimp on a ring connector.
Post #365105 16th Oct 2014 10:08pm
sparkylee
From memory I think I cut the - cable and routed it on to bar far right hand side then to battery
It has a strange terminal for the connection to battery so wanted to keep it
I did look into buying a complete - lead but too much £££££ for a 1m lead so if you do cut it be careful it is short. No length for a second cut Big Cry
These are them, the heavy duty ones
http://www.mobilecentre.co.uk/index.php?ma...=&dto=
Looking at the picture I could have got them level Whistle
From these I'm running the winch via the cut out switch mounted through the front of the seat box and also the Anderson connector also mounted on the seat box front for the jump leads which again came from Tim It's good to be back from the dark side
FFRR 4.2 vogue
Post #365114 16th Oct 2014 10:45pm
Martin
Site Admin
5th/6th items here: http://polevolt.co.uk/acatalog/Battery_Terminals.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #365122 17th Oct 2014 12:45am
Tiger
Lee,
Confused by that pic ;-?
How come you have a big fat red wire attached to the battery box?
Post #365148 17th Oct 2014 8:30am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
^^^^ I was wondering that too...!
Must be an optical illusion....Smile
Simon
Post #365152 17th Oct 2014 8:41am
