Home > Maintenance & Modifications > fixing bumperettes to x member
Caterham
Guys,
Looking to fix bumperettes as soon as it stops raining.
Any recommendations as to anything I should apply between the two surface to prevent the x member rusting / dis colouring?
Many thanks
Post #364246 13th Oct 2014 8:18pm
munch90
dab a nice load of black waxoyl covering the whole matting surface , bolt on then wipe excess of , will be good for years
Post #364258 13th Oct 2014 8:46pm
Caterham
like the idea....even more so as I have some waxoyl hanging around Thumbs Up
Post #364312 14th Oct 2014 6:29am
grafty99
A good smear of copper slip on the fixings too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #364321 14th Oct 2014 7:00am
Caterham
will do - thanks.
Post #364323 14th Oct 2014 7:12am
K9F
I made myself some gaskets from butyl pond liner. Let's hope and pray it fairs better than your EGR blank fitting clusterf**k. Ever thought of perhaps making a plan or taking advice from the forum first? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #364383 14th Oct 2014 12:25pm
gilarion
Some people take the learn by mistake route or learn by one failure at a time. Similarly these people have a time problem always thinking that it is only a five minute job or that looks easy I will have it fixed on in no time.
These same people always end up with a couple of nuts, bolts or screws left over and always think the supplier has added extra to the fitting kit in case you lose one, They read torque values and think they are just a rough guide, and adopt the approach of I will tighten the bolt up until I can tighten it no more.
For these people no matter what plan or advice is given they will still cock it up.
Not that I am saying or inferring anything to anyone Laughing
Post #364393 14th Oct 2014 1:01pm
Happyoldgit
Struth Wayne you flit around that poor long suffering vehicle of yours tinkering with this and fiddling with that with an outward and somewhat alarming air of blissful ignorance.
I await the inevitable multi page thread concerning your latest [mis] adventure with marginal interest Laughing Steve.
http://forums.lr4x4.com
Post #364448 14th Oct 2014 5:17pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I used pond liner as well!! flexible, lasts for years and easy to cut. Perfect for the job. 1953 80"
1987 mini city e
2011 90"
Post #364490 14th Oct 2014 7:25pm
Caterham
Not got any pond liner but do have a water bed liner which I suspect may be similar?
Post #364697 15th Oct 2014 4:59pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I wouldn't use anything and then you will have less to pick up when they fall off
Post #364712 15th Oct 2014 5:59pm
munch90
just use waxoyl it will dry in the joint sealing it preventing water getting in , and prevent any rust in the joint
I done the same in all joints / matting surfaces inc mud flap brackets , tow bar , bumper anything underneath
had to remove mud flap brackets after 5 years , as new underneath
Post #364719 15th Oct 2014 6:17pm
Caterham
Mal - the egr blanking went very well. Blank fitted and I now even have a spare bolt stored in the gap between engine and starter should I need it in the future.
I do need to get a replacement bracket but that said engine seems quite secure and don't expect it to fall off the egr cooler any time soon.
Anyhow not that I have a clue as to what you mean re catastrophe....box 2 of 2 got lost Monday but found and delivered today.... steering guard and brake pads....what could possibly go wrong?
Post #364731 15th Oct 2014 6:42pm
Caterham
Ta daa
Post #364893 16th Oct 2014 10:38am
Cheshire110
ooooh that makes me wince just looking at it.
Bumperettes and light guards (**in my opinion**) are a great way to ensure that a small knock or scrape does as much damage to the body as possible Shocked
Saw a nice tomb raider with rear light guards where had they not beed fitted, he'd have been replacing a bulb and a lens, but the guards made sure that he needed to repair 2 body panels, one capping and two more bulbs/lenses!
Bumperettes look the same to me! a small knock that the crossmember would shrug off now sends a piece of steel piercing through the side of the rear quarter. Not to mention misjudging a gap past a branch and catching on it Shocked
just my two cents. Cheers, David
Post #364899 16th Oct 2014 10:49am
