![]() | Home > Technical > gear box oil |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
Castrol Syntrax, fully synthetic 75w-90, is what I've used previously. I now use Motul Gear 300 75w-90 fully synthetic. Both are yellow metal safe, GL4. Some GL4/5 fluids are buffered to prevent yellow metal discolouration. They are, or were available from Autobarn, or Supercrap (on ocassion). I think there are plenty of links here in regards to the options for gearbox oils, I'll have a look later. These are just the oils I've used, there are other options. The reason I changed to the Motul was the shifts seem so much smoother, especially when cold.
I also had problems trying to get the Bot 130 in Melbourne, 2 dealers wouldn't sell it and another wanted me to re mortgage the house to purchase it ![]() Hope this helps, regards Ian. |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
Thanks Landrover in Launceston wanted 80 buck a liter and were can a motul cheers tim Cess the Taswegian
Marlin.45 Member Since: 20 May 2014 Location: Llangadog, Carmarthenshire Posts: 54 ![]() ![]() ![]() |
Try Opie oils! 2006 TD5 90 County
1961 MF35 |
