Home > Technical > Mud Stuff Heated Wing Mirrors
Dieselhead
Brought a few items from Mud Stuff tonight. Inc some larger wing mirrors.
I was temped by the heated mirror kit, but giving it some thought.
Has anybody got this kit fitted & how long did it take to do this??
Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #363990 12th Oct 2014 7:07pm
Tiger
If you want bro fit it properly and neatly (drill the mirror arms, hide the wire behind the hinge, pass the wire into the door and through the existing rubber loom boot into the bulkhead)
I reckon it's a good days work Thumbs Up
Post #363994 12th Oct 2014 7:23pm
mk1collector
Yep a good day in it to make it neat. I still need to wire up my screen and mirrors before winter Rolling Eyes I meant to do it last year but didn't get round too it and I've been putting it off all this year Rolling with laughter
Post #363996 12th Oct 2014 7:31pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I was going to do this, I've just brought some new mirrors and arms and thought I'd connect them to the heated windscreen supply.
Do you think it will take the extra load through the relay timer ?
If it's ok does any one know which side of the screen is the +
Cheers It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #364004 12th Oct 2014 7:42pm
Tiger
I've got my wires into the bulkhead.
Do we know where they then go?
How do you route them to the dash?
Post #364018 12th Oct 2014 8:48pm
Tiger
The Timer isn't the relay, so you could just up the really to a 70 amp one?
Post #364019 12th Oct 2014 8:49pm
munch90
if your going to upgrade the relay to a higher amp one then you would need to upgrade the wiring to it as well
easy way is to use the relay switched feed to screen to switch another relay for mirror heaters that way there still switched from screen switch and will use timer as well , without any extra loading on oringinal wiring
wire extra relay in normal way with fused feed etc for mirror heaters and just use switching feed from load side of screen relay
Post #364023 12th Oct 2014 9:15pm
JWL
Last year I added some heated mirror pads to my larger mirrors. On the whole my wires are quite discreet and have caused me no problems in the 18 months they've been fitted. I didn't wire mine to the heated windscreen circuit and have kept them entirely seperate giving complete control when I want them on.
As they are independant I can use them to keep the mirrors clear when it is raining, driving in spray conditions and of course when it is frosty. All these scenarios are often wanted but there is no need for the windscreen to be on plus there is very little need for a relay as the current draw is very low.
Post #364034 12th Oct 2014 10:48pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I'm half way through installing mine at the moment. I've taken a feed of the switched side of the Heated Rear Screen Switch to activate a separate relay for the mirrors. The load (and wire gauge) difference between the 2 circuits is significant and each circuit should be fused accordingly.
It's taken me ages to get round to installing these as I've never seen a method of installing that I've been happy with. I finally figured out a way to fit them and have the drivers side fitted and tested - passenger side at the weekend and then I'll write it up Smile http://defender90xs.blogspot.co.uk/
Post #366074 21st Oct 2014 5:56am
