Home > Maintenance & Modifications > Terrafirma A bar for Air con Defenders
Lorryman100
Just fitted one of these light bars from Terrafirma and what a PITA it was to fit. Firstly it does not fit as stated an air con defender without serious modification to the front grille with a dremel tool. Any ways it is on now so just waiting on a delivery of 2 pin superseal connectors and the OEM switch plug from dingocroft, then I can fit the 20" light bar I got from rustyboxx. Thumbs Up
Had to wash the Puma after I finished as it was covered in white dust from modifying the front grille. Tried the light bar and it fits with no clearance issues when mounted on top or below, think I will hang the light bar underneath but there is room to fit another on top. :?
Post #363983 12th Oct 2014 6:53pm
munch90
I would think that's the wrong one they have sent you , looks like that must be for non air con model , can't see anyone making it knowing you would have to cut the grill about !
looks neatly fitted now
Post #363991 12th Oct 2014 7:11pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I like that Thumbs Up 2005 Td5 90 XS
Steve
Post #363992 12th Oct 2014 7:14pm
Lorryman100
I thought they sent me the wrong one too but the packaging says it is for any Defender with or without aircon as standard. Ah well its fitted now.
Post #363993 12th Oct 2014 7:16pm
munch90
looks neat and better not sticking out to much anyway Thumbs Up
Post #363999 12th Oct 2014 7:36pm
LR90XS2011
not surprised everything I've brought off them did fit without modification DEFENDER 90 TDCI XS,
Post #364009 12th Oct 2014 8:01pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Looking good Brian, I've found problems with the "one size fits all" parts in the past. Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #364012 12th Oct 2014 8:08pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Lorryman,
What bumper do you have?
And which bar did you go for? I notice they have 2, 1 that is a little higher to clear a winch if you have one mounted?
Does this light bar come under the A-Bar legality issue? Or the fact it doesn't offer frontal protection exempt it?
Yan
Post #481624 12th Dec 2015 9:19pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Re: Terrafirma A bar for Air con Defenders
Lorryman100 wrote:
think I will hang the light bar underneath but there is room to fit another on top. Confused
If you're going to do that make sure you put some silicone sealant around the cable entry point into the light bar as a precaution to prevent moisture ingress Thumbs Up Don't ask me how I know Rolling Eyes 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #481654 12th Dec 2015 11:20pm
dozerman
I've got one of theirs for AC fitted to my puma (with AC) and it bolted straight on with no modification, and clears the grill by miles. I'm sure you've got the wrong one there.
Post #481656 12th Dec 2015 11:28pm
Lorryman100
@Yannis: Its an Entreq ali heavy duty bumper.
Its been on for over a year now and I ended up fitting a 28" spot only LED lightbar on the top. As for the legality, the Puma has passed 2 x MOT's with it fitted with no issues and was admired by Traffic police on a routine stop when I was working late last Christmas. I think because it is not to high and does not stick out that much with the LED lightbar fitted it looks like a dedicated lamp attachment rather than a bullbar.
Post #481661 13th Dec 2015 12:09am
Yannis
@Dozerman do you have a pic for us to compare?
Post #481685 13th Dec 2015 8:05am
dozerman
IMO the OPs light bar looks great on his bumper - the AC jobbie fitted to mine would stick out too far forwards on a non-winch bumper. Cutting the grill has left a very smart finish. However, the A bar I have is a very easy bolt on fit.
Not sure how to rotate the pics, sorry...
Post #481734 13th Dec 2015 11:24am
