Home > Puma (Tdci) > Injector coding, software update and remap? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2755 |
Hi guys,
a couple of people have recommended that doing an 'injector learn' or 'code' is worthwhile, as my 2.4 is sounding a little bit noisy under load but is otherwise running sweet as a whistle. I've also heard people mention making sure that the latest ECU software/update is installed? however i have a remap currently installed. (CSK) Can i have either the coding or the update done without affecting the remap? What would i expect to pay a LR dealer to do either of these? Should i tell them about the remap (out of warranty now)? cheers, David Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
11th Oct 2014 12:46pm |
Anyone know anything? Will probably give dealer a ring tomorrow but would like to have a bit of info first.
12th Oct 2014 12:36am |
Juhulia Member Since: 10 Jul 2013 Location: Dresden Posts: 17 |
Take the car to the remapper.
Seems like sth went wrong there. |
12th Oct 2014 7:36am |
yes maybe worth removing map then see how things are
12th Oct 2014 7:40am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
The remap file is based on what version software the ECU is running so if the ECU software is updated to a newer version then it will overwrite the installed remap file. Even if you remove the remap file and the dealer updates the ECU software the original remap file will not load as the software version has changed. Easy enough to check what software version you are running (it may already be up to date) by plugging in the remap interface or a diagnostic tool. Personally I redo pilot correction and pump relearn when I update the ECU software and after I install a new remap file
Second line down is the software version installed on the ECU, BTW this is an old picture! Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Oct 2014 9:49am |
Pretty sure an ECU update can't be done without affecting a remap, although I may be wrong.
Cost wise, just to plug in to the computer is about Ł120 at main dealers... An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
12th Oct 2014 3:01pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
David you have pm
12th Oct 2014 3:33pm |
PM replied, cheers bga.
On another note, is there some good (Mac friendly) ECU/obd reading equipment that can do this myself? (i have an OBD2--USB cable). It'd be good to read fault codes, injector learn, check updates etc., or is there nothing really between the cheap OBD apps and the more serious (read: expensive) dedicated diagnostic software. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
12th Oct 2014 4:13pm |
Just wanted to thank bga86 for the help, cheers Cheers, David
12th Oct 2014 4:32pm |
12th Oct 2014 5:35pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Sounds to me like a remap issue or the remap has pronounced it
We always chech to see if the vehicle is on the latest software before remapping ? Was this not done ? Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
12th Oct 2014 5:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
You need the remapper to tweak / check the settings, for what it's worth recently mine has been a bit noisier too and running a little rougher but nothing really to omplain about.
Had an EGR code flagged once though. Again. My guess is that on mine. Have you got the EGR closed on the remap? If you had an Alive tune you could have two maps saved, LR and tuned. And swap between the two. |
12th Oct 2014 5:53pm |
Sorry Brian, I didn't even see that paragraph! I jumped straight to the photo in your post Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
12th Oct 2014 7:31pm |
13th Oct 2014 5:52am |
