Home > Maintenance & Modifications > Middle box exhaust gaskets
jimbob7
Going to replace the mid box on my TD5,can anyone advise on which "gaskets" I need, there appears to be 2 kinds for the middle to rear box.
Or this
The same question for the front (catalytic convertor) to midd box,which is only 2 bolts but doesn't appear to have any gaskets. Pov.spec,ftw. 2006, 110,TD5.
Post #363371 9th Oct 2014 2:14pm
munch90
top one would be more like a genuine one very thin ,BUT this type is ok if both bits are new if your fitting one new section to a old section then the bottom one would seal better as its thicker and softer then the top one
two new sections with new straight ends then top one fine
one old one new then bottom one as the old part will be rusty and bit mis shaped on the flanges then fit bottom one
but to be sure whatever gasket you used , I would say a small amount of exhaust sealer wouldn't hurt anyway
Post #363373 9th Oct 2014 2:32pm
jimbob7
Cheers Munch (as always) Thumbs Up .I'll pull em apart,then see. Also gonna paint the cat and rear box,anybody have an opinion on what paint to use.There is sound theory that keeping the gases hot (insulation) improves the flow,thus more power.Any opinions?? Pov.spec,ftw. 2006, 110,TD5.
Post #363376 9th Oct 2014 2:49pm
munch90
don't bother would be my advice no way your ever get paint to stick any good on a exhaust , yes you can get high temperature paint but getting it to stick and stay stuck on is another thing ( paint puts up with heat but peels off after a while in big lumps )
any exhaust you see "painted" would be enamelled or blasted then metal sprayed or ceramic coated , chromed etc to last
paint wont make any difference to keeping heat in
wrapping the exhaust is done but normally only front pipes (wrapped in glass fibre mat normally )
Post #363379 9th Oct 2014 2:59pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
You could use something like this, tried a similar coating on the exhaust manifolds on my racer, did make a slight difference to heat transmitted through the tunnel. Thumbs Up
http://www.demon-tweeks.co.uk/motorsport/h...st-coating 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #363401 9th Oct 2014 4:18pm
jimbob7
So the zorst is off,whilst the back box is generally very good condition the flanges have lost quite a bit of metal,tho the mating surface is fine (pitted but flat),what do you think, re-fit or buy new, I can get a new take off back box for £40 ish.
Also can anyone recommend an exhaust sealant?
[/img]
[/img]
The rest of it.
[/img]
[/img]
hard to believe the middle box (below,lol) is off the same car,lol
[/img] Pov.spec,ftw. 2006, 110,TD5.
Post #364705 15th Oct 2014 5:43pm
munch90
I would replace if you can get one cheap , another job you wouldn't have to do for a while then
good sealers - gun gum , fire gum , bloseal all much the same really ( used blo seal for years , but not sure if you can get it in small tubes , I get it in the tubes for the mastic style trigger guns )
you don't want a exhaust repair putty it's bit thick , you want exhaust assembly paste
Post #364737 15th Oct 2014 6:56pm
jimbob7
Cheers bud! Pov.spec,ftw. 2006, 110,TD5.
Post #364740 15th Oct 2014 7:04pm
munch90
don't use loads of sealer ( if it oozes out the outside then it's oozing out inside as well ) no point in causing a smaller hole on inside
if your going to take a while before bolting it all up tight , wet (water) the surface of the sealer it will stop it going hard too quick
Post #364744 15th Oct 2014 7:13pm
