Home > Td5 > Any transfer/gearbox experts?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
OK, I changed my transfer box to 1.2 rather than std 1.4 a while ago and it's great.
I was assured that it was a 'goodun' and so far it's been fine, but I've got no way of knowing how many miles or wether it was worn at all, over the last thousand miles or so I've noticed the gear changes are just a bit sloppy in 1st and 2nd when pulling away.
I was underneath it yesterday to replace a seal on the rear diff, while I was there I checked how much play there was in the handbrake drum (handbrake off) and there was about 3 or 4 'minutes' of free movement (approx 20 degrees) from side to side, is this amount normal?
My worry is that the transfer box I put on was a little worn and it will wear the gearbox main shaft quicker because there is movement, if that makes sense?!!
Post #363205 8th Oct 2014 8:10pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
That amount of play is absolutely normal. Thumbs Up 2002 110 td5
Post #363244 8th Oct 2014 9:20pm
Lambley
Thanks, that puts my mind at rest, I had the same reply from Ashcroft Thumbs Up
Post #363415 9th Oct 2014 5:41pm
