Home > Td5 > Can the windscreen frame be removed? |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1097 |
Can the frame/glass be removed from the vehicle without lifting the roof off? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
7th Oct 2014 3:29pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Double post
7th Oct 2014 3:49pm |
Thats great, Thanks. The reason is I have a leak through the seal, along the top of the bulkhead, and don't seem to be able to seal it externally.
Considering lifting the screen frame out and fitting a new seal with some additional sealer to help it. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
7th Oct 2014 4:27pm |
Just a quickie, are you certain its not leaking from the windscreen seal, some I have found go to leak on the bottom corners of the frame. If you lift the seal a bit on the corners you may find where the lip of the frame is joined in the corners there's a 'step' in it. If there is they widdle in through there like nothing on earth. I'll try and take a photo of one to clarify what i mean a bit
7th Oct 2014 4:50pm |
