![]() | Home > Puma (Tdci) > Defender rear tail lights and rear wiper erratic behaviour |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
Hi lads, I have an odd problem with my 2007 110 H/T. The rear lights are all working but not as they should be
![]() I can't see any obvious fault in the loom as I stripped it back to the y piece at the back of the rear crossmember. It's driving me nuts ![]() Any ideas? Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
bad earth 100% I'd say
Lord that was quick! Where would it be earthed? I only ask because on the lorry it's bolted to the chassis directly behind the battery box.
Fair play and thanks for the prompt reply ![]() For those who do not understand, no explanation is possible |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
Does indeed sound like an earthing fault.
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 333 ![]() ![]() ![]() |
If you mean this connector then yes, thats the earth for the rear lights etc.
[URL=] ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
that's the one
thanks |
Cheers, I'll get under it in the morning and check it out.
Thanks a million ![]() For those who do not understand, no explanation is possible |
Spot on lads, everything is back working fine! The bold was a small bit loose
![]() Thanks again Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
![]() Just goes to show what odd things can happen with an earth faulty. |
that's good then , nice to have a easy fix once in a while and not the dramas that defender ownership can bring
I'm still in shock that it wa that simple!
