![]() | Home > In Car Electronics > Problems listening to music via USB |
Not an Alpine unit but with my Defender and Company Car on a USB stick or memory card you have to access the media on the stick or card via the menu 'Flat Directories' to get access to the music. If you go through life with your head in the sand....all people will see is an ar5e!!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
Files are most likely protected for copyright / piracy reasons.
They'll only play via a synced Apple device. Unless they are not encrypted, AAC or .MP3. If your music was iTunes purchased it will be most certainly be protected files. |
V12vanquish Member Since: 28 Sep 2014 Location: Northern Ireland Posts: 52 ![]() ![]() ![]() |
I think the files need to be MP3.
I had a similar problem getting music files to play on another car. I ended up using windows media player to convert the files to MP3 format, copied onto a memory stick and it worked fine. I'm currently using this same memory stick in my new Defender with no problems. The only thing I don't like is it sticks out in the dash, it's going to get clouted sooner rather than later and probably damage the radio. Last edited by V12vanquish on 5th Oct 2014 8:16pm. Edited 1 time in total |
Some can support AAC and MP3, generally MP3 is the most widely covered format.
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 ![]() ![]() ![]() |
I had to convert all my iTunes to mp3. There's an export function on iTunes but it still took hours... Defender Puma 2.2 XS 90
Vespa GTS 300 Way too many racing bikes. |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Thanks for all replies.
For now, I have connected the iPod but will try again when I have a spare evening. 1970 Series 2A 88" |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 ![]() ![]() |
Interested in the answer to this. My USB memory played fine in my previous Kenwood unit but will only play about 3 albums on the standard MY14 XS Alpine unit. I'm too busy to find out why and am playing the iphone into it via USB or Bluetooth depending on how far I'm going. Cheers, Guy.
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
I think I will invent a simple disc to put music on that just plays the tunes without any faffing about with a computer!
....oh.....no wait thats been done before ![]() |
