Home > Technical > Cutting TD5 From Running |
Disconnect or take out the crank position sensor.
3rd Oct 2014 3:37pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Unplug inertia switch on the engine bulkhead 02' 110 TD5 Double Cab Rebuild Thread
3rd Oct 2014 5:23pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Inertia switch 2002 90 Td5 Station Wagon
3rd Oct 2014 7:33pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6103 |
^^^^ +1
Or if you can't be bothered to unplug it, just give it a whack, or if you're feeling strong, turn your rover over 360 degrees. |
3rd Oct 2014 7:34pm |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
unplug injector loom
7th Oct 2014 2:39pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
+1 on the injector loom. Quick and easy
7th Oct 2014 2:43pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Inertia plug did the trick, nice and simples !
7th Oct 2014 9:34pm |
