![]() | Home > Puma (Tdci) > Updates |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
scary!
clutch maybe, some say ECU update, but I got lost already how many versions are. Puma 110" SW ............................................................. Earth first. Other planets later |
Hi Brendon,
check the vac pump for leakimg seal and you could ask them to the QV068 V2 up date 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Dont touch software uogrades if it aint broken!
http://www.defender2.net/forum/topic2455.html?highlight=software 1964 Series IIA SWB Truck Cab - gone 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
update QV068 verson 4 has caused the issues 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5080 ![]() ![]() ![]() |
Dont worry - they will put the latest version on anyway - when the link it up (part of the service) it will automatically do it
Add anything you can see faulty to the list - they wont change it if its not. Mike |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
seals at both ends of the prop, i've had THREE on each end!
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
Clutch, clutch master cyl, rear view mirrors become very loose off road, vacum pump, low range whine, dust entry, gear chang between 1st and second, trans clonk, poor body alignment. But then its a Defender and we will live with it.
![]() ![]() Allan |
We do enjoy our Land Rovers. Just after the service it is off to Denmark, Sweden and possibly the Baltics
Brendan |
