Home > Wheels & Tyres > Trye pressure guages
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Looking to get a tyre pressure guage. Is there really any difference between them? When i was a lad we had one of them metal jobbies that are now all over e bay for two quid and seemed to work fine back then!!. Do i really need to spend 15 quid on a dial one or digi one?
Post #361413 1st Oct 2014 12:29pm
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Dial ones are pretty good, easy to read (which is good when your eyesights getting crap - it's an age thing!)...and I usually find with digi things the batterys run out just when you want to use them...but they are probably more accurate than the others! 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #361433 1st Oct 2014 2:13pm
JWL
I bought a "cheap" Halfrauds digital one about 7 years ago and it still works!
Post #361446 1st Oct 2014 2:51pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Get one like this... they don't go wrong or need batteries and are dead easy to use Thumbs Up
Post #361450 1st Oct 2014 3:14pm
GUM97
I've got a PCL pressure gauge/inflator. Calibrated twice a year, and not cheap at about £50 but it's never let me down during daily use! An engine to TDi for!
Post #361534 1st Oct 2014 7:50pm
Post #361539 1st Oct 2014 8:05pm
Cuthbert
I bought a brand new rather expensive PCL 'professional' grade analogue pressure gauge - Made in Sheffield - no batteries or electronics to degrade and thought it would do the business for many years.
It's now sitting in the hall cupboard awaiting what might be a one-way ticket back to Sheffield.
After using it on several vehicles that I own - I'm totally unconvinced as to its accuracy. Currently using a rather cheapo Halfords plastic unit that appears to give more consistent and accurate readings.
I also have a PCL tyre inflator and the integral gauge on that unit appears even less accurate.
Post #361583 1st Oct 2014 10:32pm
