![]() | Home > Maintenance & Modifications > Mig welder...?? |
something like this , for me would be sealey before Clarke
eBay item number: eBay Item No. 290406179943 to be honest your not going to get a top make for that budget (kempii , Lincoln, boc, murex etc) your in the sealey/Clarke budget (hobby not professional ) but you can get good results still , good welding is down to good preparation , nice clean metal (more so with mig than stick arc ) get comfortable and something to rest your torch arm on to steady it don't buy the max amp you can get for the money and stay clean of unknown makes amps your need at a guess 130-150max this would still good for much thicker than a land rover chassic , don't forget duty cycle will go down as you go up in amps , doubt this would be a problem with amount of welding your do in one weld on a chassic and if possible get some spare metal the same thickness as your going to weld to get used to welder and get welder set up before you start (might save a few blow holes in weld!) sorry if you know how to weld just trying to be helpful if you don't |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1031 ![]() ![]() ![]() |
Not my specialist area, but when I was researching R-tech kept being mentioned http://www.r-techwelding.co.uk/Mig_Welder/240V_Mig_Welders Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 ![]() ![]() |
+1 for R Tech - I have one of thier TIG's and it does what it says on the tin. I do use a proper bottle of Argon from BOC though.
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
I have one never used apart from a practice weld. Am i too far away? Cant remember what make it is though or what I paid for it. Like i said its practically new and it would be cheap. Pm id of interest and i can see what it is!!
