Home > Technical > TD5 Rattle
Page 3 of 4 <1234>
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Bit more info for anyone who may be able to help.
I did an ECU pull on the way home from work. Whilst I dont know if the Cylinder balance data is accurate as I read somewhere that it's not fast enough to be of use, I do seem to be getting some odd readings here any there, mainly on cylinder 5.
Does this show up a potentially duff injector?
Just not sure where else to turn at the moment!
Few screenshots of the recorded data:
Post #360179 25th Sep 2014 8:24pm
mk1collector
Anyone?
Post #360719 28th Sep 2014 10:22am
taazzukcb
Bit more I tried yesterday (I may as well keep posting what I can in case someone can help :p).
I took rocker cover off and checked everything out. Cleaned out the injector loom and reset the injector bump clearance. Dont think it's made much difference to the rattle. All set to exactly 1 turn out from end point. Nothing's moved or shifted under there.
Tempted to try the injector seals and washers again, but I dont have any of the others signs that they're bad. Plus, they're only a couple months old (same as loom)!
On the way home on Friday, I had some hesitation and now my clutch pedal rides right at the top. I know the argument of the pedal riding high when imminent clutch failure is due is a contentious point in the mechanical world. But is this a sign of again, clutch or DMF?
Master and slave are fine. They were both changed just after I picked her up and the fluid level is fine.
Might all be useless info, but I may as well post anything and everything!
Cheers.
Post #360724 28th Sep 2014 10:41am
mk1collector
My rattle noise that's a bit intermittent was worse today so I took it to the garage and they thought DMF which was my original thought so it's booked in for next week Big Cry I'll post up if it's cured
Post #365054 16th Oct 2014 7:55pm
taazzukcb
Mine's still going and getting worse!
Sounds a right bag'o'nails in the morning!
Goes a little when warm but still there! and it's definitely engine RPM biased. Dip the clutch and the rattle is still there, but just at idle speed and not at road speed RPM.
Every day almost I'm crawling around under it trying to pin point it!
Driving me mad and taking all enjoyment out of it.
Just need to be sure it's the DMF before I outlay the dough! Have a lot to buy for it over the next few weeks!
Just dont have the usual signs like slippage! Very confused!
Post #365057 16th Oct 2014 8:02pm
mk1collector
I'll let you know how mine turns out
Post #365104 16th Oct 2014 10:06pm
taazzukcb
MK1,
Did yours sound anything like this? (Yes, another video :p) ...
Keep listening and you may be able pick it up.
Anyone else able to help still too?
On a side note, does anyone have a sound clip of a TD5 miss firing when running?
Cheers.
&feature=youtu.be
Post #365209 17th Oct 2014 1:21pm
mk1collector
When you were stationary (so there was no engine roar or wind noise) I could here what sounded like mine. If your sat stationary in neutral with the clutch pedal pressed and rev and let off the accelerator a couple of times does it make the rattle in time with revs and if you let the clutch out and rev again is it quieter? This is what mine seems to be doing which is why we think DMF but mine sounds like the clutch release bearing might be on its way out too which is also causing a low rumble when pressing the clutch. Mines in next Thursday so I should have some more ideas by next weekend hopefully.
Ray
Post #365249 17th Oct 2014 4:10pm
taazzukcb
I've put all the sound proofing and stuff back now so sounds ultra quiet, but that's just getting used to the quietness again compared to being open.
I dont think mine changes clutch in or out really. This is what's making mine more puzzling (to me anyway). Clutching doesn't effect it except when rolling as I press clutch in the rattle drops with revs (engine rpm, not road rpm).
Post #365543 18th Oct 2014 9:56pm
mk1collector
The DMF turns at engine speed so the rattle would drop with the clutch in, if it was the dmf
Post #365548 18th Oct 2014 10:33pm
taazzukcb
Sorry, not sure I worded right. Fully understand about the DMF being engine speed Wink.
I meant on idle, clutch in, clutch out, the same. When running, like you say, it's engine RPM dependent Smile.
Post #365552 18th Oct 2014 10:58pm
mk1collector
Well the clutch and DMF have been changed and on mine it has made it a lot quieter and smoother to drive but I still have a little bit of a rattle like yours. Mine seems not as loud as yours but the clutch work didn't change the rattle. Sorry.
Ray
Post #366885 24th Oct 2014 3:25pm
taazzukcb
mk1collector, Hmm ... damn ... I assume you did the clutch release and spigot bush to?
I may have asked this, but yours still rattle with engine running and clutch in but revving it?
Post #367047 25th Oct 2014 9:41am
mk1collector
Yes, everything new. My rattle is really intermittent, it isn't there every trip. It also seems to mainly be under load but in the very low bit of Rev range it's seems to go with higher speed, also if the throttle isn't pressed at all it doesn't rattle.
But with the new parts it's a lot quieter overall.
Post #367055 25th Oct 2014 11:14am
Anderzander
Ray - did you solve your rattle ?
Post #420578 2nd May 2015 6:46am
Page 3 of 4 <1234>
