Home > Wheels & Tyres > BFG MT pressures |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
32 Front & 38 Rear? ... Rog...
The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
25th Sep 2014 2:59pm |
Doesn't get much quicker than that Venomator Well done! If you go through life with your head in the sand....all people will see is an ar5e!!
25th Sep 2014 3:02pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Thanks....kf9, do you agree?
25th Sep 2014 3:04pm |
Precisely what her indoors says, although she forgets to add the last bit... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
25th Sep 2014 3:08pm |
I do agree indeed. Just for clarification purposes it's Jonno's tyre pressures posted by Mr Venomator I am agreeing with and NOT with Mrs Venomator as I have no experience, nor wish to of Mr Venomator's sexual prowess.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Sep 2014 3:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20343 |
Mal.
32F 38R on mine too on a 90. How much is it costing you may I ask? |
25th Sep 2014 4:11pm |
Steve, from another thread.....good source for tyres that may give you a benchmark.....
25th Sep 2014 4:17pm |
£135 for a full set of 5 including balancing I was charged, think I was had.
25th Sep 2014 4:48pm |
Get a set of dynabeads and you need never pay for balancing ever again. That too after the initial outlay reduces the cost further in future tyre swapouts. If you go through life with your head in the sand....all people will see is an ar5e!!
25th Sep 2014 5:05pm |
Are they legal?
25th Sep 2014 5:40pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
I run 32 in all corners. Anything above 34 makes it harsh.
Andy |
25th Sep 2014 5:45pm |
Might try the above myself, mines a little harsh on the rear but not when towing so that tells me it might be a little high.
I don't generally take very heavy loads either in the back or towing. |
25th Sep 2014 5:50pm |
Fitting was 75 all in. For 5. Formula 1 tyre depot, all done in 45 mins. HOWEVER....just noticed that the writing has a blue tint to it and there is lots if over spray on the sidewalls...should i complain to paddocks or is that normal??
25th Sep 2014 6:31pm |
Normal, mine was the same.
25th Sep 2014 6:37pm |
